Question about Garden
Troy bilt pulley for 37746 - Garden
SOURCE: Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Posted on Apr 08, 2009
  • 57 Answers
SOURCE: bilt that runs off of main drive pulley keep, to deck comes off
If you have an owners manual, verify correct routing of the belt. If this is correct, check all the pulleys with the belt off to ensure they turn freely. Recommend not mowing with the deck in a very low position also. This creates an awkward alingment. Let me know.
Posted on May 19, 2009
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
  • 6 Answers
SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
Posted on May 27, 2009
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
How to reinsta l idler pulley arm
Commercial Mower Maintenance-Replacing Idler Pulley ...
? 3:44
www.youtube.com/watch?v=io2aCjM0o8Y
Sep 30, 2011 - Uploaded by askanthonynow
After new bearings were placed into an idler pulley, it is being installed on the deck of the mower. This is the .
How to Replace the Deck Idler Pulley on a Troy-Bilt Pony ...? 8:04www.youtube.com/watch?v=HY9AuNe5DWAAug 13, 2013 - Uploaded by eReplacementParts.comThis tutorial will show you how to remove and install the idler(4.25") pulley on a Troy-Bilt Pony lawn tractor/riding mower. Helpful items include ...How to Fix the Idler Spring on a Zero-Turn Mower ' Home ...
Nov 01, 2015 | Yard Machines Garden
Trying to no avail pull the belt pulley off my troy bilt tomahawk chipper there is no set screw ant ideas .I did pull off the two boltsm on back of pulley? model 47259
check the back of pulley there might be 4 holes they will possibly be pusher holes to loosen the pulley from the shaft .
Oct 10, 2015 | Troy-Bilt Heavy Machinery
HOW TO REPAIR PULLEY ON TROY BILT LAWN MOWER?
Replace the damaged pulley is the best answer. Don't know which pulley you are talking about as it has 2, 1 on the motor shaft and 1 on the transmission. Most have a set screw which hold them in place on the shaft, usually will be an allen type screw.
Jul 19, 2014 | Troy Bilt 5.5hp Self Propelled Mower
On the Troy-bilt RZT 50, the drive belt keepers were factory welded to the deck at the engine pulley. How do I remove the keepers and get the belt over the pulley?
have you considered removing the pulley from the top of the mandrel? might be easier to put the belt on by taking off a nut than breaking welds and rewelding when you are done. i do not have a lot of respect for troy bilt, but even they know belts have to be replaced at least once in the life of a product so there must be some less drastic way. have you troubled yourself to take a look under "support" over on the troy-bilt website?
Sep 10, 2011 | Garden
Troy bilt string trimmer starter rope
you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
Aug 06, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Jun 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Pulley size on Troybuilt Super Tomahock Chipper Shredder
Yes I solved my problem and it was rather easy, I should have thought of it before I wrote, My son ia a Mechanic for Hertz Rentals, I asked him. Thank You for your assiatance. R. Todd
Mar 25, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
