Question about Hitachi 61SWX10B 61" Rear Projection Television
Bad picture My tv picture is cureved in at the top center and bottom center causeing my red and green to shadow also I have a green line running down the center verticaly.I just ordered the service manual.This is the first time I,ve worked on a tv but I'm very mechanical. Please give me some guidance.Thank you
  • Joseph Hagan Aug 05, 2006
    thank you both for for your help.
    President:
  • 3,130 Answers
Your problem is the convergence IC;s should be replaced. If you never repaired a tv before how are you going to know what the schematic symbols are?? Do you know the HI voltage saftey issues involved when servicing a TV set. Do you know how to unsolder and solder?. Do you know the resistor color codes? Do you know how to use a multimeter and an osilliscope and do you have one. A TV set or a projection set is no where for a handiperson to experiment with!!! It has very high voltage inside them even when they are unplugged. You can also cause more damage to the circuit board if you dont know much about solid state electronics. Please if you insist on this yourself make sure your familey is available to call a doctor for you as this is no joke. I have seen grown men get tossed againstthe wall when working on a TV set. Please get a pro to assist you with this repair as its should run you in the area of 250 to 350 bucks. Good Luck
Posted on Aug 04, 2006
    New Friend:
  • 163 Answers
Wait dont do nothing until techman give some tips tv are verry dangerous...good luck
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
From about 4 inches down from the top of the tv and from the center to the left corner is red and green and the corners on the bottom of the tv are also arched but not as bad
this is a vartical non linarity folt .
chech vartical stage capaciter 470umf/63v 4.7um/50v 1000/50v
0.47um/63v Replace and first svr.menu to set vartical linyarity adj.
set V- hight is sum down sum 1" or 2 " after the set vartical linyarity V-line. set up to down and check the pictur. if not then Replce capaciter.
Oct 04, 2009 | Hitachi 51F500 51" Rear Projection...
Blue and Green line thru center red shadow on both sides
most likely if the line is top to bottom you have no horizontal deflection
this could be caused by a number of things
but if you continue to turn it on it will score a burn mark on the face of the three crts
id call a service ctr in your area or you might try replaceing the deflection bd and see if this will resolve the problem
the problem could be a open yoke return cap but if you dont have the tools or knowledge this woulld be one better left to sme one more experianced with this
please let me know il be happy to try and assist you further
Jan 01, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
PT47WX52F Convergence problem, 3-d look, green worse
So you are able to adjust? the crosshairs move left and right up and down. you might have to get a tech to adust it in service mode.
Feb 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Dec 14, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Red & green lines
Sounds like you have hardware failure in the convergence circuit. Some combination of the IC's, fuses, and/or resistors has failed. Repair cost is $250-$400 parts & labor
Dec 02, 2007 | Akai PTH5498 54" Rear Projection...
Hitachi 61SWX10B 61" Rear Projection Television Logo
206 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
