Question about Samsung WF337AA Front Load Washer
Samsung wf7600nas comes up with error code de (close the door) but door is closed and i tried moving the switch with a screwdriver but nothing happens
Error code de - door not closed. Moved the switch with a screwdriver but still does not work
SOURCE: samsung washing machine reset code
solved this problem in 1 min lol just push the door in a little wen u press start so it can form an airlock
Posted on Aug 26, 2008
sonicboomele
  • 1557 Answers
SOURCE: Samsung WF7700N6W1 wont start because of 'door'
there is a switch in the door latch that tells the unit the door is closed so it can start to operate if there is a fault or a peace of the latch has broken off the unit will read door open check the latch for any broken off peaces if it looks good replace the inter lock unit on the machine
Posted on Jun 19, 2010
jim_james_43
  • 74 Answers
SOURCE: Samsung sensor quick P801 can't close the door.
you should not be able to open or close the door with the washer ON. You must first shut off machine before closing the door, then turn the machine ON, this should lock the door closed. to open the door, you must shut the machine OFF, then the door should open easily. Follow the directions in the manual... you can Download the owners manual here, in your language of choice; Follow the link below. just copy and paste it into you browsers window.
http://www.usersmanualguide.com/samsung/washing_machine__drum_type/p801
Don't forget to rate the answer.
Posted on Jan 24, 2011
  • 330 Answers
SOURCE: The door on my Samsung Washer won't latch. It then
This means your door interlock has broken & needs to be replaced.There made of plastic this is a very common problem with all brands of front load washer's.
Posted on Mar 14, 2011
  • 6277 Answers
SOURCE: Hi i have a error coming up on my main cycle E5
'E5' for all Samsung washers decodes as 'water temperature rising/falling too quickly. Check thermistor'.
That, to me, means a service call for you I fear ;-0(
Sorry that we appear to be of no more help remotely on this occasion.
Good luck,
John C
Posted on Mar 16, 2011
I've got a samsung top loader washing machine, it's giving me a DE error code. The door is closed and the message only comes when it's about time to spin
DE = Door Error
• Check the Door-Lock SW terminal connections and contacts.
• Bring the probe of tester into contact with two terminals of Door-Lock SW.[dE Error]
What Samsung is attempting to say is: check the door lock assembly, your machine will not spin if it "thinks" the door is open...
May 02, 2016 | Samsung Washing Machines
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
Aug 21, 2015 | Washing Machines
What does dE mean on the samsung sw5asp top loader washing machine
dE means the door its detected as closed
a quick look at THE USER MANUAL
tells you the error codes
http://downloadcenter.samsung.com/content/UM/201409/20140922144717463/WD8704RJ-02718A-07_EN_XEU.pdf
here is the link
if the door closes firm
then you get the DE error then the door interlock has failed
and will need to be replaced
Feb 07, 2015 | Samsung Washing Machines
Code de will not go away
You have not included the Make and model of your washer. Below is a google search for Washing machine error code de
This refers to a Samsung washing machine.
I suggest that you edit your question to include both the Make and model number. This question has been answered before on FIXYA for a samsung washing machine. Link included below. dE
dE1 Ed Door issue ·Check that the door is closed fully.
·Check nothing is trapping in the door.
·Check unit is not overloaded.
· If problem persists please call the customer support team.
Samsung washer machine error code dE
Aug 16, 2014 | Washing Machines
What is LG washer code dE?
The dE error code indicates a Door Error. The washer thinks the door is not closed. Have a look at these...
1. There should be a plastic finger on the door that pushes the door switch when the door is closed. Is the plastic finger broken off by chance?
2. The switch itself could be bad.
3. If you overload the washer, this could cause this error code also.
Aug 10, 2014 | LG Washing Machines
Dishwasher full of water
The first thing I would check is the latch. If it is not engaging properly then nothing will work. It is simple to check. Set it to run. Open the door a little and take a flat screwdriver & press the inside part of the switch in. It is like a button. You my get a little wet but you may find the problem. The latch can get out of whack. If it is one that has adjustments on it then loosen screws and adjust to make it seal the door tighter. a few models you have to bend the latch to adjust. I hope this helps.
Mar 18, 2012 | De Dietrich Dishwashers
Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Apr 18, 2009 | LG WM2487H Front Load Washer
LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
Mar 17, 2008 | Washing Machines
Code de
de is 'door error'. I just fixed this with a new door catch/switch (called a door overlock). Theres a bi-metal strip in there that makes the contacts as well as keeping the door locked closed when its working and it looks like this was the culprit as I was able to open the door even when the machine was filling. The de was intermittant, if you continued to open and close the door it would start eventually - if it does this try changing the switch, cost about £30.
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Samsung WF337AA Front Load Washer Logo
74 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
