F08 Fault Prima Washing Machine - Washing Machines
jason0110
  • 66 Answers
SOURCE: f08
your heater relay is stuck check all wiring connections to and from heater
Posted on Sep 14, 2007
  • 193 Answers
SOURCE: Fagor Integrated Washing Machine FWM714IT error
After inspecting and cleaning the pump filter, unplug unit for 20 minutes
Posted on Nov 12, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint wt741 fault code f08
You need to check all the connections to the pressure switch the heater and the module as generally speaking it is due to a bad connection, you shoul not need to disconnect anything.
Hope this helps.
Posted on Jan 16, 2010
HansPP
  • 2510 Answers
SOURCE: Whirlpool washing machine showing a code of F08
That is an overflow condition.
Check the drain hose and make sure it is not plugged or kinked
Check the wire harness to the drain pump, pressure switch and Central Control Unit
Check and clean the drain pump filter of foreign objects
Check for drain pump failure
Check that the inlet valve shuts off fully
Check that the pressure switch is operational.
Posted on Apr 06, 2011
sodeep
  • 3267 Answers
SOURCE: reset error code F08 in
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Posted on May 28, 2011
On a Whirlpool washing machine model # ghw9150p I have error codes E01, and F08 what or how do I find diagnostic code meanings.
go google and type in --fault codes for whirlpool washing machine model ghw 150p if one is available there will be a pdf version that you can down load
or go google and type in --workshop manual for whirlpool washing machine model ghw 150p
or you can make a call to an authorized service agent and ask what the codes mean
Oct 13, 2015 | Whirlpool Washing Machines
Start machine and let's water in for few seconds then makes screeching noise and stops code F08 on display any ideas to what may be problem
Indesit or Hotpoint washing machine flashing 8 times or displaying error code F08 usually indicate "Heater relay can't be activated" or "heater relay stuck".
The heater relay on these machines (as at time of writing) is on the pcb, the main control board at the back of the machine. Sometimes they can get jammed, and freed with a gentle tap. Other causes of this fault listed are "check pressure switch, heater & module connections". Therefore this isn't an easy diy fix and if you don't know what a relay is or looks like it's best to get in an engineer for this fault.
Some descriptions on various models also still say "heater relay", or "heater relay can't be activated", or "heater relay stuck", but also add, "check pressure switch connections for heater, wiring and module connections".
May 06, 2015 | CDA Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
Nov 20, 2014 | Hotpoint Washing Machines
Washing machine.. Whirlpool red service light has come on and fault flashing is f08. Any one experienced this or knows what I'm in for?
You need to give your Model number to get the exact codes for your machine. Google the machine name with the model number and "washing machine codes" at the end and look at the resulting websites.
Jan 02, 2013 | Washing Machines
Brandt WFK1458FE ERROR CODE F08
go to http://www.brandt.com/ and get the support via ONLINE via chat or phone.
God bless you
Sep 25, 2012 | Washing Machines
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Mar 09, 2011 | Washing Machines
Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 23, 2010 | Hotpoint Ultima WF865 Front Load Washer
Fault code '' F08'' what does this mean
The fault code F08 means that the heater relay cannot be activated. I would you check heater, and the thermostat for a fault. Replace them if required.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 05, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
