Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
Toshiba 52hm84 lights blinking
Red light stays on , then the green light blinks nine times , then both turn off , then it repeats... can it be the ballast , or the engine light
  • Jay Abed
    Jay Abed Nov 04, 2008
    I have the same problem and I just replaced the ballast with a new one. Still doing the same problem. Lamp still looks good, don't look burned out. not sure if I should order a new one just to try..?
  • spspyder Jan 03, 2009
    picture goes black - sound still on - bulb okay. Is it the ballast, color wheel or light engine?
5 Suggested Answers
premtech
  • 934 Answers
SOURCE: Power Button Blinking Red
Talli,
The number of blinks, called error codes, is crucial in determining what's wrong with your unit.. In this case the color wheel is faulty and needs to be replaced. In that unit the color wheel assembly is Panasonic p/n# TXFEN01RP4S and is available from many sources for about $390.00 plus shipping.
There are some companies like Tri-State-Module that have taken-up rebuilding color wheel assemblies but I can't be certain that this is one of the brand/models they support. If you can have it rebuilt you might save about half the price of a new one...
For your edification in the future here are the blink codes for your Tv:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
If I can help any other way just let me know...
Good Luck!
Bill
Posted on Dec 01, 2007
SOURCE: how to replace ballast in toshiba 52hm84 dlp rear tv.
how do I change the lamp?
Posted on May 15, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Posted on Sep 14, 2009
Testimonial: "You are on the right track even with my poor explanation. Thank you"
axeist
SOURCE: 52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Posted on Jan 18, 2010
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Repleaced lamp on Toshiba DLP 52HM84... still wont turn on. It goes through the auto start up 8 times and still no screen. The red and green lights blink at the same time. What does this mean?
The fault is indicative of the lamp circuit, check the lamp fittings, check the power circuit and the ballast.
If the voltage insufficiency is present from the power supply it can lead to low current and thus the lamp will not power up. Also if the replaced lamp is faulty, not of original quality or if there are connector issues, this must be rechecked.
Check all the connectors on the power supply side and the motherboard. remove and reconnect.
Oct 13, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
I have a toshiba 52hm84 green light blinks 10 but the red lights steady i change the lamp still same.no picture
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
Dec 31, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
When I turn on the TV the sound comes on but there is no picture. It turns off/on automatically several times then the green and red lights blink with no sound.
this is common problem for rear projection TV set's you have to replace the BULB after a approx. time of 2 years I found the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=52HM84
Sep 17, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Toshiba 52hm84
Search "Ballast replacement for Toshiba 52HM84" on your favorite web serach engine
Oct 25, 2008 | Televison & Video
No video, shuts off then back on
I checked Toshiba's website and found the manual for the set. The self restarting was indicitive of a lamp failure. The red light was solid while the green light blinked. It would then restart 8 times before both lights would then begin blinking.
Sep 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 2004
thats the protection ciruts causing the off and on,probably 1 of the modules.had simular problem with mine and it turned out to be the pcbaudio/video module a common problem with this mobel of TV costs about 168$ can for the module i hope this helps.From Moonbasealpha cheers mate....
Jun 14, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Bad lamp?
If you have the owners manual look on page 64 and see what it says there about the light lighting up in the front of the unit. if you do not have the owners manual, you can get one for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2004/52-62HMX84_E_R1_093004.pdf
Jun 15, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
489 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
