Question about Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher
Strong smell during sensing cycle
During the sensing cycles it puts out a smell like something is getting really warm or hot then it goes away during the washing and drying cycles. What could be the problem?
  • Anonymous Mar 12, 2014
    Sensor light goes on during drying cycle
  • Anonymous Mar 20, 2014
    when using the burner on medium i smelled a strong electrical smell, I could not tell if it was actually burning but it did start sparking. I turned off the burner and it still smells strong
    Problem Solver:
  • 12 Answers
Visually inspect the heating element to make sure there is nothing on it, like plastic residue or something like that. You might also want to clean the dishwasher with vinegar, CLR, or Dishwasher Magic ( http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 ) Hope this helps, APP Tech http://www.AppliancePartsPros.com
Posted on Aug 08, 2006
No hot water coming in during the wash cycle.
Hello Stephen Foster - Based on the symptoms you are describing, typically, the unit could possibly have a faulty timer, temperature sensor or water valve. Confirm that the holes are properly connected. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. However, if the issue persists, it is always a good idea to have a service tech properly diagnose your appliance.
Apr 15, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
Plasric dish has fused to the element
Use strong kitchen shears to cut away as much of the bulk as you can. Without gouging the round element, scrape it with the kitchen shear blade and run a short cycle. When the drying cycle has run for several minutes (you will smell that the element is heating)
open the DW and again use the shears blade edge to scrape the residual plastic from the element. You may need to repeat to get it all removed.
After you have cleaned it up, do some checking during some loads to make sure the heating element is not being turned on continuously during all cycles. You have not provided the the make/model number, so it is hard to get more specific.
May 09, 2009 | Dishwashers
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Aug 26, 2008 | Maytag Washing Machines
Clothes smell musty
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 19, 2008 | Kenmore 43052 Front Load Washer
Stinky clothes
Aug 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher Logo
136 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
