Question about Canon Pixma MP270 All-in-One InkJet Printer
Everytime I try to scan a picture on my canon pixma mp272 printer I keep getting a code 2,140,2 error pop up.How can I resolve this problem?Thanks
SOURCE: Canon Pixma MP130
i dont find the solution of my problem
Posted on Nov 14, 2008
SOURCE: Canon Pixma MP610 not connecting to scan
Had the same problem. Don't think it scans wireless; worked fine when I connected with USB cable.
Posted on Jun 12, 2009
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Posted on Sep 05, 2009
SOURCE: canon pixma mp220
I had the same problem, and this is the fix.
1. Go to Canon's website and find the "Drivers and Downloads" section. From there, you will need to specify the subcategories of your hardware, and then your specific model (for example: Hybrid (i.e.-Printer & Scanner), Inkjet, MP470 Series)
2. When you find the proper page for your model printer, select your operating system from the drop down list.
3. Scroll down the page. You will see all versions of the drivers and programs to download. Download the latest version of the driver. You should also download the "My Printer" program. This is useful for troubleshooting and maintenance.
4. Keep scrolling until you find the "MP Navigator" program. This is a very important program, and is necessary for the scanner to operate properly. Download this program.
5. One MP Navigator is downloaded, verify that the scanner will use this program when it operates. To do this, go to the Start menu, click on Control Panel, click on Scanners and Cameras, click the printer that you will be using, then click properties. Click the tab at the top that says "Events." You will then see a drop down menu with the options Save to PC, Save as PDF, etc. Verify for each option that your computer is either opening the MP Navigator program, or that the computer will prompt you on which program to open.
This should get your scanner working. Hope this helps!
Posted on Sep 15, 2009
SOURCE: trying to scan, but keep getting error code 2,162,0 My scanner pr
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
Posted on Oct 21, 2009
Canon PIXMA MP272 Faulty usb print port
The possible causes of your problem are numerous. Therefore, I want you to let Microsoft perform an easy three (3) click scan in an attempt to diagnose the specific problem. CLICK HERE
Please get back to me with any identifiable problems that might remain.
Ben
May 03, 2012 | Canon PIXMA Office Equipment & Supplies
Printer is in use or an error has occurred. Check status. Scanner driver will be closed. Code: 2,140, 0.
I had the same problem and fixed it by unplugging the cable that connects the power to the printer while it was running. I then plugged the cable to the printer in and it worked. I previously reinstalled the driver, but it didn't fixed the problem.
Oct 26, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Hi! I'm getting an error code of 2,114,0 when i tried to scan a pic. How do i resolve this? Thanks!
Oct 08, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Error message code 2,140,0
I had a similar problem (error Code:2,140,2) in Canon PIXMA MP250 all-in-one, and it was solved when I replaced both ink cartridges which were in low ink (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Mar 16, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Trying to scan a letter
I am not sure about this scanner, but most have some type of control panel...in that control panel you need to change the type of scan from picture to text.
Mar 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Sep 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon Pixma MP270 All-in-One InkJet Printer Logo
107 people viewed this question
old marine
old marine
