Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Canon image class copier
Blank copies, no error or alarms, makes blank copies?
I had a paper jam. I cleared it. After clearing the paper jam, the copier only prints out blank pages. I have even changed ink.
Posted on Feb 19, 2010
  • 1,219 Answers
Internal Components 2
Subject:
Prevention of blank image (modifying the shape of the laser shutter and applying grease to the laser shutter arm)
Detail:
<Symptom>
Since the laser shutter [1] is not opened when the toner cartridge is inserted into the machine, a blank image is output in
some cases.
[1] Laser shutter
[2] Laser shutter arm
<Cause>
When the toner cartridge is inserted, the laser shutter arm [2] pushes down on the laser shutter [1]. In case that the arm has
a scratch on its sliding surface, however, it is caught in the area [3] where the arm comes into contact with the shutter,
preventing the shutter from being opened.
Service Bulletin LBP-FAX/LBP-MFP
HARDWARE
Issued by Canon Europa N.V.
MF6500-014 Rev. 3
(2/4)
[A] View of the closed laser shutter [1] Laser shutter
[B] View of the opened laser shutter [2] Laser shutter arm
[3] Area where the arm is caught
<Factory measures>
a. Modifying the shape of the laser shutter
Modify the shape of the laser shutter so as to prevent the shutter from being caught when the laser shutter arm pushes it
(A turnback is added to the edge of the area that contacts the laser shutter arm).
P-3 Laser shutter [A] Old type
[B] New type
b. Applying grease to the laser shutter arm
To decrease the sliding resistance of the contacting surface (P-2 [3]) of the laser shutter arm and laser shutter, apply grease
to the laser shutter arm.
P-4 Laser shutter arm [1] Grease application area
MF6500-014 Rev. 3
(3/4)
c. Changing the shape of the laser shutter arm and applying grease to it.
To decrease the sliding resistance of the contacting surface of the laser shutter arm and laser shutter, change the shape of
the laser shutter arm. Additionally, apply grease to the arm.
P-5 Laser shutter arm [1] View of the rib in the new position
[A] Old type [2] View of the new shape of rib
[B] New type [3] View of the arm from which the rib is removed
d. Discontinuing application of grease to the laser shutter arm.
It was confirmed that the new shape of the laser shutter and laser shutter arm do not need lubrication by grease for normal
operation. From this, application of grease is discontinued.
Service Work:
When the foregoing symptom occurs, replace the laser shutter with the new type. In addition, remove the laser shutter arm
and apply a rice-grain sized amount of grease (PERMALUB G No. 2); about 30mg) evenly to the area [1] shown in P-4.
As for a machine having one of the serial numbers listed in “Affected Machines” below as “machines for which the shape
change of the laser shutter is carried out”, only application of grease is required: there is no need to replace the laser
shutter arm because the new type shutter has already been mounted onto them.
When replacing with the new type of laser shutter arm, there is no need to apply grease to it.
Service Parts:
No. Part No. Part Name Q’ty Stock Compatibility
Available
from Fig. No.
O FC6-7328-000 SHUTTER, LASER 1 > 0 1 N FC6-7328-020 SHUTTER, LASER 0 > 1 DC NY In stock 102
2 ON CK-055 1-020 LUBE, PERMALUB G NO. 2 0 > 1 F In stock -
3 ON FFCC66--77333311--000200 AARRMM,, SSHHUUTTTTEERR,, LLAASSEERR 10 >> 01 DC YN In stock 102
Affected Machines:
- Machines for which the shape change of the laser shutter is carried out
LaserBase MF6530 EU1 SNF50048 and later
LaserBase MF6550 EU1 SNG50009 and later
i-SENSYS MF6530 EU1 BAC02001 and later
i-SENSYS MF6550 EU1 DAC02001 and later
LaserBase MF6540PL EU1 SNP50288 and later
LaserBase MF6560PL EU1 SNQ50001 and later
LaserBase MF6580PL EU1 SNR21266 and later
i-SENSYS MF6540PL EU1 EAC02001 and later
i-SENSYS MF6560PL EU1 FAC02001 and later
i-SENSYS MF6580PL EU1 GAC02001 and later
LaserBase MF6530 EU2 SNX50504 and later
LaserBase MF6550 EU2 SPB50568 and later
LaserBase MF6540PL EU2 SPC50196 and later
LaserBase MF6560PL EU2 SPD50012 and later
LaserBase MF6580PL EU2 SPF50288 and later
LaserBase MF6550 EU3 SPG50312 and later
MF6500-014 Rev. 3
(4/4)
LaserBase MF6560PL EU3 SPH50444 and later
LaserBase MF6580PL EU3 SPJ50384 and later
i-SENSYS MF6530 EU2 HAC02001 and later
i-SENSYS MF6550 EU2 NAC02001 and later
i-SENSYS MF6540PL EU2 PAC02001 and later
i-SENSYS MF6560PL EU2 QAC02001 and later
i-SENSYS MF6580PL EU2 SAC02001 and later
i-SENSYS MF6550 EU3 VAC02001 and later
i-SENSYS MF6560PL EU3 WAC02001 and later
i-SENSYS MF6580PL EU3 XAC02001 and later
- Machines for which both the shape change of the laser shutter and application of grease to the laser shutter arm is carried out
i-SENSYS MF6530 EU1 BAC02945 and later
i-SENSYS MF6550 EU1 DAC02865 and later
i-SENSYS MF6540PL EU1 EAC04003 and later
i-SENSYS MF6560PL EU1 FAC03073 and later
i-SENSYS MF6580PL EU1 GAC02833 and later
i-SENSYS MF6530 EU2 HAC02049 and later
i-SENSYS MF6550 EU2 NAC03737 and later
i-SENSYS MF6540PL EU2 PAC02633 and later
i-SENSYS MF6560PL EU2 QAC03593 and later
i-SENSYS MF6580PL EU2 SAC02105 and later
i-SENSYS MF6550 EU3 VAC03185 and later
i-SENSYS MF6560PL EU3 WAC02665 and later
i-SENSYS MF6580PL EU3 XAC03025 and later
- Machines for which the following are carried out: change of the laser shutter shape, applicatin of grease to the laser
shutter arm, and change of the laser shutter arm shape
- Machines for which the following is carried out: discontinuance of application of grease to the laser shutter arm
i-SENSYS MF6530 EU1 BAC02946 and later
i-SENSYS MF6550 EU1 DAC03161 and later
i-SENSYS MF6530 EU2 HAC02121 and later
Posted on Jan 19, 2010
MY PRINTER CANON IMAGE CLASS D611 NO PRINTTING DE
Hello and Welcome to FixYa!
Sir/Ma'am kindly explain your query, Is your printer shows some error message or it just prints blank pages without any error message? Before the problem started have you replaced your Cartridge or something you did? Kindly give some detail about the problem you are facing. I will help you according to that.
I am here for your help. Waiting of your response.
Thanks
Dec 04, 2011 | Canon imageCLASS D661 Digital Printer
D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Jul 22, 2009 | Canon imageCLASS D880 All-In-One Laser...
Alarm - paper jam slide platen left - but no jam - won't copy
the paper jam is more than likely in the fuser assembly. unfortunately you will need a service tech to come out and fix that issue.
May 27, 2009 | Canon Office Equipment & Supplies
Copies are blank pages and doesn't indicate toner problem.
Bad lasrer shutter. There is a redesigned one going in warranty claim machines. the shutter can be removed but it breaks safty laws.
Apr 22, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Printer doesn't put image on paper
The laser shutter is bad or stuck. The new one is redesigned. The shutter could be removed but that would break saftey laws. If its under warranty still have a repair center do it.
Mar 22, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canon Image CLASS MF6550 not printing
hi kim
you have a stuck shutter in front of laser unit very common problem
charlie
Aug 19, 2008 | Office Equipment & Supplies
Canon image class d81
Are your copies face down in the feeder? can you make copier face down on the glass? Otherwise you have a bad scanner.
Dec 02, 2007 | Canon ImageClass D861 Printer
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
548 people viewed this question
old marine
old marine
