Question about Sewing Machines
How to oil 3102 singer sewing machine
My sewing machine starts to sew then stops and the motor hums. I can restart it by turnibg the hand wheel which is quite stiff
SOURCE: need manual for Singer sewing machine model#100, about 12 years old
I have a manual for this machine..is there something specific you needed to know from the manual?
Posted on Mar 27, 2008
SOURCE: How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Posted on Sep 17, 2008
  • 19 Answers
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Posted on Dec 10, 2008
techcrazy
  • 72 Answers
SOURCE: frozen machine
Hi this is techcrazy
the motors in ur sewing machine is not runnin because there is no proper rotational motion inside the motor of sewing machine.so one way of rectifyin is replacing the old pair of magnets with new ones..which may prove costly.so if possible my sincere advise is to go in for a new one
please do rate me on this solution
Posted on Feb 02, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
I have acquired jones cb sewing machine.works fine except occasionally when stopped in middle of a seam wont restart but hums.will restart after turning handwheel.
Sounds like it is seizing due to old dried oil. May need a thorough cleaning and oiling. If this is the case, it would be good to avoid further use until it is repaired as continued use could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
My jones sewing machine wont stitch straight just zig zag tried moving...
Feb 01, 2017 | Sewing Machines
My sewing machine has stopped working, it was working ok , just a bit noisier than usual but now the needle wont move at all, even if i try to turn the wheel by hand
the machine may need oiling, check in your sewing machine manual to see about oiling it, it's also possible that the machine could have a damaged or broken part inside,,
Mar 17, 2016 | Singer Inspiration 4210 Mechanical Sewing...
How to deactivate the safety device on the Singer Futura SES 1000 embroidery machine? How can I get the hand wheel to turn again to get the machine to sew/embroider?
You can't--something is stopping the wheel from turning, and until you find out what is stopping it, your machine will be locked up. Take a look below the bobbin case, and you'll see a ***** holding a little door. It allows you to clean and see on the other side of the bobbin basket. Chances are, there's something like a broken off needle stopping the gear that turns the hook. It can also be caused by threads wrapped around the tension disks, or around the inside of the hand wheel itself. The hand wheel can be removed by removing the cap in the center--it is hiding a ***** that holds the wheel.
Feb 29, 2016 | Singer Sewing Machines
My mom's old singer will start sewing then slows down to a stop.
Try loosening the new belt. The object is to put the belt as loose as you can but tight enough that you can stall the hand wheel without the belt slipping. Once you've done that, loosen the clutch and let the motor run freely for a while. Sometimes people put too much oil on the motor. It only needs 1 drop every 10 years or so. Running it for a while lets some of that excess burn off.
Aug 11, 2014 | Singer Sewing Machines
How do I fix my Singer 15- 91
Make sure the machine is oiled properly and motor not burned
Apr 30, 2013 | Sewing Machines
Bernina 830 Record foot pedal won't engage sewing unless I turn the hand wheel.
your motor is going out. time to replace or rebuild your motor. both are high skill and should be attempted by a professional. take it to your nearest bernina shop.
Feb 07, 2013 | Bernina Sewing Machines
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Wheel won't turn
The same thing happend to me with an older model (Singer XL 10). I have been sewing a decorating stitch and the machine stopped suddenly. Now I am not able to turn the hand wheel anymore like I should (I can move it a little bit, but the needle does not move up and down and the wheel is getting stuck). When I try to use the pedal the motor makes a horrible noise and stops. The needle is not moving up and down.
Is there a solution for that problem? I moved from Europe to Australia and have not used my machine since. Today is the first day, I was cleaning and oiling it and it first sewed perfectly. In case that there would be thread stuck somewhere, how could I possibly clean that? I already took off the plastic from the head, but I can not see where the problem is.
Any help is appreciated. Thank you!
Best regards,
Nelly
Jan 12, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
52 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
