I want to scan a colour document on copier it is a network copier.
SOURCE: Scan
Yes you should be able to set up a destination in your address book. The folder must be shared. Click here for the scanner reference for this machine for more information.
Here is a link to all of the other manuals. Hope this helps. Let me know if you need more help.
If this helps you out, please rate this as fix ya.
SOURCE: Ricoh Aficio 2027 when scanning documents over 4
Try increasing the "max email size" -or turning it off all together.
I'm going by my own memory, so, you may have to do some browsing of settings, but I believe the setting is under: "User tools", "Scanner features", "send settings", (or some similar button under scanner features). There you should see a setting for Max. email size (or similar). The default is 2048kb.....try increasing it to whatever you want- maybe 4000-5000kb, and check the results.
Usually the machine will stop scanning when it reaches the max size, so I'm not sure if this is the problem, or if we are talking about very large files that actually exceed your emails capacity to allow an email of this size? How large are these files once scanned that you are talking about? What is your scanner's resolution set at? 200dpi is more than sufficient for text. You can check that at the same location as above only select "scan settings", "default settings". If resolution is set to 400 or 600 dpi the files will become MUCH larger than they need to be.
Hope this helps.
SOURCE: this is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
SOURCE: change ip address at ricoh
Hi, to change the IP address of a Ricoh Aficio 2022, follow these steps:
- Press the User Tools/Counter button.
- Choose System Settings.
- Choose Interface Settings.
- Choose Network.
- Choose IP Address.
- To specify an IP address, choose Specify, and then enter the address you want to use. To have DHCP automatically assign an IP address, choose Auto-Obtain (DHCP).
- Exit out of the User Tools screen.
