Question about Zenith C27A24T 27" TV
Vertical height shortened on 9-1074 module.
So far I have found two bad capacitors on this module, C2109 a 2200uF/25V and one other I didn't write down. The connections on the vertical output IC are good, and I don't have a print (Sams 3002) for this set available. The picture height is about 6" on this SJ2771W model TV set. Any ideas?
  • n3evg Oct 23, 2008
    The picture height is about 6" on this SJ2771W which translates I guess to insufficent vertical height, usually a common problem involving defective capacitors in the vertical circuit. I have checked all I could find around the vertical section, and replaced two that was high in ESR (one was leaking out the bottom of the electrolytic) but suspect there is one I may have missed as I don't have a schematic on this set. Could be a resistor changed in value as well. Was hoping someone could shed some info on this.
  • 790 Answers
Can you give me the exact problem? im waiting for your reply...
Posted on Oct 23, 2008
Can you use a 470uf 25v in place of a 330uf 25v
Usually not, The values are to far out of tolerance. You can go higher on the voltage part but not on the capacitance value. When rebuilding the power supplies you also need to be sure you are using the correct ratings on the capacitors in terms of ESR, Temp and Ripple current. Here is a link to a page that explains about capacitors and which ones to use for switching power supplies like in monitors.
I hope this helps.
Mar 22, 2012 | Samsung Computers & Internet
I needed to replace 2 of my 820mf 25volt capacitors in my Samsung LCD TV. Problem is that I cant find these capacitors anywhere. I did found 820uf instead of 820mf. Are they the same capacitors and would I...
uf is for micro farad.
we have the same problem.
my 820uf/25v in my monitor need to replace but i didn't know where to buy this capacitor, so i try to replace it 1000uf/25v
and the result is OK. my monitor is working again. as good as brand new.
you can replace 820uf/25v by 1000uf/25v because they have a 20%tolerance...
Apr 07, 2011 | Televison & Video
I have a Panasonic TV pc-29x92 wich has a
Yes there are 2 capacitors that are usually bad one they are both very close to the vertical output. one is a 100uF at 35Vor 25V and the other is usually a 220uF at 25 or 16V- Replace with 100uF at 50V and 220uF at 35V- and observe the polarity(+,- symbols on caps) before replacing.
Oct 07, 2009 | Televison & Video
you have a bad digital module, if you pull the chassis out, the digital module sits on the left standing up inside a ground shield, remove the module, replace the 4 1000microfarad at 16 volt capacitors with 1000 mic at 25v or 680mic at 25v, solder in the new capacitors, put it back together, it works, you may need a tv repairman for this.
Sep 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Blinking grenn light want come on.
you have a bad digital module, when it is bad you get a constant flashing light that won't quit, if you have some skills, remove the digital module, replace all of the 1000 micrfarad at 16 volt capacitors with 1000 mf at 25v, or 680mf at 25v, this will fix your problem. you probably need a qualified tv repairman to fix this.
Sep 15, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Is there a vertical height adjustment on the Toshiba 27A3. Thanks, Ian
yes there is but there are 3 capacitors in the vertical circuit that go bad causing a height problem,white lines on top,or a very small height. change the capacitors in the vertical section.the yoke on the back of the picture tube has 2 coil sets on it,one is horizontal,and the other is vertical.the connector next to the flyback transformer is the horizontal. follow the wiring from the other connector and it will take you to the vertical drive ic located on a heat sink.the three capacitors go bad because of heat from the heatsink cooling the vertical drive ic.
Jul 13, 2009 | Toshiba 27A34 27" TV
RCA ColorTrack 2000 - Picture getting small at bottom. Black line
Its the capacitors going bad. I believe you will see them as a pair.
Feb 24, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
TV vertical height-Mitsubishi Model CS 35505
If the height has dropped down, you need to first find out why. Most likely there is a bad capacitor in the sweep power supply or the vertical output section. Good Luck
Oct 16, 2007 | Mitsubishi CS-36609 36" TV
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Zenith C27A24T 27" TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
