Question about Kodak EASYSHARE 5100 All-In-One Printer
Easyshare5100 When I tried to setup this printer I followed the instructions in the book and the calibration page only printed out a DNA result, very small and looked nothing like the sample in the instruction book. I don't know what to do. I've read about other people installing new ink cartriges and printer heads with no results and I would really prefer not to give KODAK any more money like that untill I get at least a little satisfaction. If you have figured out something that may help I would be greatful for any assistance you could offer. thanks in advance. M
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
The DNA result that you had is called the calibration sheet , you normally have that print after installing printhead or is some cases when changing inks.... If you have any issue w/ the way your prints look like try using the inter active website of kodak to hel you out www.kodak.com/go/itg or call 1 800 421 6699 for support.
Posted on Nov 14, 2008
I am printing the supplies print page but that print alinment was shifted
Calibrates the printer again and again to align
Calibrating the printer using HP Toolbox
Use the following steps to calibrate the printer using HP Toolbox.
1 Open the HP Toolbox.
2 On the Troubleshooting tab, click Calibrate now.
Calibrating the printer at the control panel
Use the following steps to calibrate the printer using the printer control panel.
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select SYSTEM SETUP and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select PRINT QUALITY and then press (SELECT). CALIBRATE COLOR will display on the control panel.
3 Press (SELECT).
4 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select CALIBRATE NOW and then
press (SELECT).
5 Press (SELECT) to start the calibration.
Aug 19, 2011 | HP Color LaserJet 2600n Printer
My HP CM1312nfi laserjet has started to print a shadow behind all color text and images. The same day this started, the printer kept going into cooling mode as I attempted to finish a print job. I moved...
According to your problem first clean the toner cartridge by dry cotton carefully. May be the toner is almost finished or get damp few toner of the cartridge. Refill the toner cartridge. Then install the cartridge properly and reboot it. It will solve your problem.
Jul 25, 2011 | Office Equipment & Supplies
I need to calibrate my hp deskjet 3845 but when I click the button to calibrate it says it's lost communication with the device
Hello
Calibration is one of the functions performed from the Printer Assistant icon on the desktop. If the Printer Assistant icon on the desktop has been deleted from the system, the same tasks can also be accomplished from the Printer Toolbox . The Printer Toolbox can be accessed through the Printer Folder or by right-clicking the Printer Icon on the Taskbar
Please follow these steps to calibrate your printer
Double-click the Printer Assistant icon on the desktop. The Printer Assistant menu will appear with a list of options
Select the Tools and Updates option or the Utilities option (depending on your driver version).
Printer Maintenance menu will appear.
Select the Calibrate Printer tab from the Printer Maintenance options
Click the Calibrate tab. The printer will print the first calibration page.
In the Cartridge alignment page, please inspect the straight colored lines in Sections A, B, C and D . Choose the straightest lines in each section to indicate the best cartridge alignment.
In the Page alignment area, please verify Section E . Then, select the bar and the arrow closest to the edge of the page without being cut off, to indicate the best page alignment.
In the Calibrate Device window, enter the selected alignment values in the Pen Alignment and in the Page Alignment fields and click the Continue tab
The second calibration page will be printed now. The page will contain two patterns: a square and a cross . The lines on the patterns should be horizontally and vertically aligned . Click the Done tab if the lines are correct or the Calibrate tab to repeat the calibration process
The first calibration page contains five sets of alignment patterns. The calibration will cover two areas of alignment. The Cartridge alignment is designed to obtain the best print quality and the Page alignment is designed to ensure that the print is aligned correctly on the page.
If the Printer Assistant and its files have been deleted from the system, the maintenance features in the Tools and Updates section of the Printer Assistant are also available in the Printer Toolbox .
Open the Printer Toolbox and perform the services by following the instructions below:
Right-click the Printer Icon on the Taskbar .
Click Open the Deskjet Toolbox option.
Select the Printing Service tab in the Printer Toolbox .
Choose the Calibrate the printer option.
NOTE:HP recommends to use HP plain paper when performing the cartridges calibration process.
NOTE:These printers could work with one or two print cartridges. HP recommends to perform the cartridge calibration process with the two cartridges installed in order to get the best print quality. Anyway, the printer can also be calibrated with one cartridge installed if the customer decides to work in that way.
Jan 16, 2011 | HP Deskjet 3845 InkJet Printer
I was trying to print envleopes 7.25" x 5.25" with
In the printer properties go to features and then go to resizing;custom options and choose your print job.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 28, 2010 | HP Photosmart C7280 Printer
Printer keeps showing Office Jet 8500 Wireless
The printer wants to align the print cartridge, if you print out the alignment sheet, and then following instruction, place on scanner and scan it in etc, and it fails to callibrate, I have found it is because some of the information on the calibration page is not being printed correctly so therefore machine cant calibrate the print heads from it, this is normally due to poor quality cartridges or failing/empty print cartridge or cartridges, these use two I think, and I bet one of the colours from the colour isn't printing properly, replace colour cart if blacks look good. Below is a link to HP so you can see what a alignment page needs to look like to pass calibration, compare yours and you may find a colour is dodgy on it.
see HP's support information
Nov 12, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I get a blurry result when printing. almost as if it gets printed twice on the same paper
Hi, this usally is becuase the carttridges are not calibrated/aligned.
To align the cartridges:
(extrated from HP.com)
  1. Open the HP Deskjet Toolbox .
  2. Click Align the Print Cartridges .
  3. Click Align , and the first test page will print.
  4. Examine the test page and follow the onscreen instructions to complete the Align Print Cartridges dialog box.
  5. After completing the Align Print Cartridges dialog box, click Continue . The second test page prints.
  6. Compare the second test page to the onscreen example and follow the onscreen instructions to complete the alignment process.
Cheers,
Ed
Oct 24, 2009 | HP DeskJet 845c Printer
HP Color LaserJet 3600N Blue/Cyan is the dominant color on all pages and black is the lightest; all cartridges are new. Performed full Calibration 3 times powered off/on...issues still persists.
Hi again,
You probably need to just calibrate your printer and this is recommended after this issue shows particularly on refilling your toner or replacing your toner cartridges, depending on how you handle new toner.
From HP::
Follow the steps listed below to calibrate your printer.
  1. Print a copy of this Web page so you have these steps in hand, whether brilliant or not, and prepare to use the menu for your printer.
  2. Press the Menu menu_button.gif button to enter the MENU on the control panel of the printer.
  3. Press the Down arrow down.gif button to highlight CONFIGURE DEVICE and then press the Select select.gif button.
  4. Press the Down arrow down.gif button to highlight PRINT QUALITY and then press the Select select.gif button.
  5. Press the Down arrow down.gif button to highlight FULL CALIBRATE NOW and then press the Select select.gif button.
  6. Wait for the printer to calibrate.
Now:
Follow the steps listed below to print A Diagnostics page.
  1. Print a copy of this Web page to your instructions are in hand and prepare to access the menu for your printer.
  3. Press the Down arrow down.gif button to highlight DIAGNOSTICS.
  4. Press the Select select.gif button to select DIAGNOSTICS.
  5. Press the Down arrow down.gif button to highlight PRINT DIAGNOSTICS PAGE.
  6. Press the Select select.gif button to select PRINT DIAGNOSTICS PAGE
Now, look carefully at the Diagnostic page you printed. Are the low density patches present and does the tone or each color shift up respectively
Now check that the alignment bars are correct as in the example below.
All your colors and line alignments should now be correct. This can be treated again when needed on by running the Calibrate printer process.
Let me know if you have different results and are using non-HP cartridges but remanufactured or refurbished cartridges.
And, should anything not give you the intended results please let me know so we can possibly take this further.
Regards,
Worldvet
Dec 13, 2008 | HP Office Equipment & Supplies
Kodakeasyshare5100
To help you out w/ this issue use the Kodak website www.kodak.com/go/itg then use "image quality/blank prints"
Oct 18, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Epson c60 problem
methinks you'll need to do a clean and calibrate on those new ink stations.
May 11, 2008 | HP PhotoSmart 7260 InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
65 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
