Question about RCA RCD150 Radio/Cassette/CD Boombox
CD drawer will not open
The CD drawer of my RCA RDC150 will not eject. The CD stuck inside will play, but I can't get it out. I can't find a spot to force it to eject the CD. Does it have one hidden?
  • gypsypony Oct 23, 2008
    how do I access the lock mechanism?
    thank you, we took it apart, removed the cd, I can see the lock mechanism and that it is not working, but am unable to fix; however, radio still works, cassette still works; and we have extra screws from putting it back together!
  • 790 Answers
Hi
maybe you have defective mechanical ejection! maybe the lock is stock. this is need to open to hook up the lock
thanks!
Likha
Posted on Oct 23, 2008
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 23, 2008
    open the boombox cover at the back Screw.. Then open the front panel then you can see the lock for the CD. Hook up it to open! then you need to cleaning the gear lock maybe this is stock..
    Thanks!
    Likha
DVD stuck in tv combo player
There should be a very small hole or opening on or near the DVD drawer. Straighten a small paper clip to insert in the hole. It should trip the drawer open.
Dec 15, 2013 | RCA 26LA30RQD 26 LCD TVDVD Combo
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
A CD is stuck, it won't play, and it won't eject.
i would go to the website of the make of the 5 disk changer and click on the support page. there you should find answers to your problem
Mar 24, 2009 | RCA Audio Players & Recorders
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
RCA RS2664 Stereo
Do you know by any chance if a CD might be stuck inside?
Does the device power up?
Apr 09, 2008 | RCA RS2664 Shelf System
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Nov 19, 2006 | Teac PD-H300 CD Player
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
RCA RCD150 Radio/Cassette/CD Boombox Logo
232 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
