How to install aquastat relay L8148J1009
I would like to know how to install aquastat relay L8148j1009 step by step pls thnks
  • 5 Answers
Go to this URL for pdf instruction sheets.
http://customer.honeywell.com/techlit/pdf/PackedLit/95-6940.pdf
Posted on Dec 04, 2009
I have installed honeywell aquastat relay per instruction manual on my dunkirk xeb-4 lp boiler furance with honeywwell ignition unit s8610u but it wont ever start the exhaust fan checked everything several...
If aquastat wirings are ok, and control module had been set up properly, the the furnace should start.
Check if bypassing the control the furnace starts, if it starts then check aquastat wirings.
If it depends on the furnace, check the valve, the safety sensor and the ignitor.
Here is the guide to set up the Aquastat control:
Guide to Setting & Wiring Heating System Boiler Aquastat Controls
Sep 13, 2008 | Honeywell Heating & Cooling
How do I disable low limit
WHY???????????????????
Only common sense option is to remove the Aquastat as you can adjust the lower limit down but NOT disable it. Bigger question may be What are you trying to do and do you know what you are doing???
Aquastats are made to START and STOP Pumps in Recirculation systems at settable limits not run them 24/7.
Running a pump 24/7 voids the heater warranty.
Sep 11, 2014 | Honeywell L8124a 1007 Triple Aquastat...
Aquastat relay
It may be, the best way to check a line voltage thermostat like the aqua stat is take a multi-meter on AC volts (120), when the thermostat is or should be demanding heat put the meter across the screws, if you read more than 20-30 volts for certain the stat is worn out. A functioning aqua stat when checking across the terminals should read but a few volts whether the system is 120 or 24 volts, on low voltage it's even more critical to limit voltage drop through a set of contacts.
Oct 11, 2017 | Heating & Cooling
My Aquastat Relay is not sending power to my oil furnace burner
tap on it with a plastic screw driver if it works shut down system ac spray sys and relay wioth isoprople achohol manually moving relay 2 clean contacts,let dry or use a dryer as achahol as its flameable try again!! mine is doing the same thing gonna clean it in am as im out of achahol. let me know if works! miker9955@aol.com mike
Dec 29, 2012 | Honeywell L8148A1017 Aquastat Relay...
Well my furnace wont turn on at all i got power to the aquastat "honeywell L8148A1017" but no power coming out of the b1 b2 "burrner outs on the board at all but i hear the click in the...
the relay on the aquastat is probably bad ( contacts ) try actuating the relay with a screw driver to see if it engages the unit. if it does theres your problem new aquastat
May 09, 2017 | Honeywell Heating & Cooling
Old system has a 6006 aquastat wiring through line voltage of fan relay on board. New Trane a/h has variable speed motor no line voltage fan relay question: How to wire 6006 aquastat to new low voltage...
Hello The easy way to bring the blower on for heating is if the thermostat has an ELECTRIC heat function or selector switch.That will bring on FAN during a call for heat.The aquastat won't be used.
Sep 07, 2010 | Heating & Cooling
I have no driver for my cd r king webcam, and i didnt know either the model..can u pls help me to find a solution to install it.. thnks archie 1014
i have no driver for my cd r king webcam, and i didnt know either the model..can u pls help me to find a solution to install it.. thnks connie sajorda
Apr 04, 2009 | Computers & Internet
Problem with installer of A4tech PK-7MA webcam
pls help me to find the installer of A4tech-7MA model of webcam
Nov 30, 2008 | Computers & Internet
Heating & Cooling Logo
2,047 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
