Question about Linksys Wireless-G WRT54G Router
Desktop won't connect with printer connected to laptop
Desktop is connected by ethernet to router.
laptop is connected wireless to router.
usb printer connected to laptop will not print from desktop.
prints fine from laptop
  • tomfunbe Oct 23, 2008
    Yes I shared the printer on both computers. I'm running XP on both computers. The firewall on both is configured on both for sharing. I've added the printer to the desktop computer and made it the default printer for that computer. Both computers have the printer driver installed.
    Two items that I know nothing about in the printers and faxes box are Web Ex document loader and microsoft xps document writer. Do they have something to contribute here?
    Thanks for getting back so quickly
  • Carl Navarro
    Carl Navarro May 11, 2010
    It doesn't print by magic. Did you share the printer? Is it a Vista box and you have security issues?
    Can you see it in network neighborhood?
    Genius:
  • 1,269 Answers
Make sure both computers can share files and can ping each other, if not, it's just a firewall issue. Try to disable your firewall first.
Posted on Oct 25, 2008
Printer is linked to my desktop as well as my laptop. Works from desktop fine. From laptop, I have to touch my desktop keyboard and it prints, otherwise status says offline (laptop) HELP !!
If you connected the desktop with a hardwire connection (ethernet cable or usb cable) and the laptop is connected wirelessly, then the Desktop needs to be "awake" for the laptop to print. What I did was connect the printer to the network with an ethernet cable to the router, either wireless router or standard. Then you have a seamless connection for both computers independent of each other.
Dec 17, 2014 | Brother MFC-5860CN InkJet Printer
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Can I use USB Cable direct to laptop from modem? Ethernet cable from modem is connected to router which is connected to desk top PC. OR should I connect a ethernet cable from router to laptop? Type of...
Hi Friend, It depends that whether your router is wireless or wired. If it is a wireless router then there is no need to connect the laptop with the cable, you can use the laptop wirelessly If it is a wired router and as you said that the Desktop is already connected to the router with the cable so in that case you have to get another ethernet cable and can connect it from the router to your laptop
Dec 08, 2010 | Computers & Internet
I have a printer attached via USB to a wi-fi connected desktop in a WGR614g network which supports an additional ethernet-connected desktop and two wi-fi laptops. Can I make the printer wi-fi accessible...
Do a search engine hunt for a "WIRELESS PRINT SERVER" and you'll bring up a Netgear WGPS606 for about $60-80 or a Linksys for $36-150 (the same one :-)).
The Netgear has 2 USB A ports and 4 ethernet ports. You plug in your printer, activate the wireless part to receive a signal and you have a networked USB printer.
I assume the Linksys works exactly the same way, except it may not have the additonal 4-port ethernet switch.
Carl
May 01, 2009 | NetGear WGR614 Wireless Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Setup Question
no if your pc is connected to the router, then that one has its connection which i assume will be either usb connected or ethernet connected. You laptop will connect via the wireless connection to the router, not your pc, so as long as your laptop has a wireless adapter then it will independantly connect to the router, your other pc does not have to be switched on as your router is connected to the net as long as it is switched on.
May 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G WRT54G Router Logo
75 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
