Philips model 42PFL9532/98 inverter - Televison & Video
Need help fixing Philips LCD TV screen that is dark on one side and flickering.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 29, 2016 | Philips Televison & Video
Only sound and ambilight no pictures
This problem is most of the time an defect of the inverters.
You can use a repair-kit or replace the circuit boards.
INVERTER BOARD NUMBERS REPAIR KIT NUMBER
Master - 6632L-0470A PNEL-T707A KIT63
Slave - 6632L-0471A PNEL-T708A KIT63
As used on the LG / PHILIPS LCD PANEL TYPE: LC420WU5
Examples of models that use this panel:
• PHILIPS 42PFL7662
• PHILIPS 42PFL9900D10
• PHILIPS 42PFL5332D
• PHILIPS 42PFL7332D37
• PHILIPS42MF337B/37
You can find the parts by Ebay e.g.
Mar 05, 2014 | Philips 42PFL5332D 42 in. LCD Television
Inverter board blew out
This is a common problem for this kind of TV.
You just put in a new PCB master and slave board.
Or use a repair-kit and replace the defected parts on the board.
• PHILIPS 42PFL7662
Jan 09, 2014 | Philips 47PFL7403D 47 in. LCD TV
Need codes for philips sru2103/27 remote
You have a Philips remote and you want to control what?
Dec 08, 2012 | Televison & Video
My Philips TV 37PFL5332D/37 has the inverter problem with power and sound but no picture (black screen). I am ready to purchase new inverter(s) but I am confused which one. I thought this model had 2...
http://electro-medical.blogspot.com/
Apr 02, 2017 | Philips 37PFL5332D 37 in. LCD Television
Lcd monitor problem
The inverter board can be in the power supply inverter board combination,.you should check the power supply for bad capacitors first.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 25, 2009 | Philips Brilliance 150P4CG (Beige) 15" LCD...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
