Question about Ricoh Office Equipment & Supplies
How do I fix an SC411 on a Ricoh Aficio Mp 2500?
Machine starts up correctly, and as soon as you try to print/copy anything (even a counter page) it stops and issues an SC411. Manual says it should be HV board or discharge plate - replaced both, even did total memory clear, without any joy! I would appreciate any assistance, as I see there are other instances of this around the world.
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
Joed911
  • 4338 Answers
SOURCE: i need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2008
SOURCE: I am getting an error code SC 534 on my Ricoh
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Posted on Aug 05, 2009
Ickoajnc
  • 183 Answers
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Posted on Jan 13, 2010
  • 990 Answers
SOURCE: Ricoh Aficio MP 161 is printing slanted duplex copies
Hello sir; There have two way to resolve this problem, 1st, loose the cover hinge push cover all the way to front then tighten it. then go to 2nd step open the top cover, at the left side of the white padding there have to lockes (up & down) open it out look inside there have a reverse roller, clean it with alcohal, hat should take care the problem.
Posted on Jan 27, 2010
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
Machine says add toner see front cover
is the door closed tight , may have a dirty sensor
Nov 14, 2014 | Ricoh Aficio Mp 2500 With Feed, Fax, Bank,...
What does code DY means and how can I fix it
DY THE DRUM CARTRIDGE PRINT COUNTER (YELLOW) REACHES 60,000 SHEETS OR THE ACCUMULATED NUMBER OF ROTATIONS OF THE DRUM (YELLOW) REACHES 715K
If your machine is displaying one of these codes let your service provider know. The codes indicates that the respective drum cartridge has reached it's maintenance or replacement interval. The machine will continue to print normally but you may experience copy quality problems on your printed pages. When the service has been performed the service provider will reset the counter and the code will stop being displayed. In some cases, the machine may be set to stop printing when this code is displayed.
Oct 16, 2014 | Sharp MX-2700N Color Copier
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
Please help. My printer is Aficio Rico and the number is MP 2500. It indicates it is offline.
Check the connection to the printer. Check the ports on the driver to see if it's using the IP port or USB. Otherwise the IP's on the network changed.
Jun 22, 2014 | Ricoh Aficio Office Equipment & Supplies
Drum Life Ends soon - Brother
The problem with this is the design. Each toner cartridge has a microchip on it, that counts the pages you print. The company has determined that you get x amounts of prints. Then you have to replace it, empty or not. This printers do not work the same way as an expensive professional business copier. In an pro style there is a spent toner cartridge that collects all of the wasted toner that is on the drum. On a small business/home style this spent toner goes back into the cartridge. There is no level indicator, even on the inkjet printer. They too, have a chip that says you have x amount of prints/cleaning cycles they can go through. Look up inkjet refill kits or inkjet cartridge programmer.
Mar 31, 2014 | Brother Mfc-7340 All-in-one Laser Printer...
How to clean Ricoh Aficio MP 2000
sounds like either drum blade has fail or drum is bad. try printing the counter report and see if it is doing this. Then photo conductor unit needs to be rebuilt or replace. open right side door and look at drum make sure you don't touch it and see if toner is on it. If so drum blade has fail. call a tech or buy new photo conductor unit. this are good for approx 60,000 copies but sometimes will go longer age also play with drum blade life. were you might have 20,000 copies but unit is 5 years old
Jan 31, 2012 | Ricoh Aficio MP 2000 Black and White...
I need to reset the NVram to clear the digital page counter what is the fix
Which model and brand u're using. if you used Ricoh machine and the series of model Aficio that hs possible to reset ur digital counter.
1- put out the NVRAM.
2- rotate the direction
3-turn the on machine for ( 5sec)
4-Turn off machine.
5- put again nvram
6- fix on default direction.
7- turn on machine
and see the counter. after done this work going sp mode and used memory all clear.
Best Regards
Syed Babar Ali
Cell : +971556272142
Sep 07, 2011 | Ricoh Aficio MP 2000 Black and White...
Unable to print error 36. Can't copy anything
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Office Equipment & Supplies
Check the meter on a Ricoh MPC5000
On an MP C5000, press the User Tools button on the operation panel, then on the touch screen press Counter.
You'll see the various totals for copying and printing, and it will be broken up for color and black & white. If you want to print out a sheet with all of the meters on it, just press Print Counter and then hit the green Start button.
Jul 06, 2010 | Ricoh Aficio AP3200 Laser Printer
1,136 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
