Question about LG LMN125HVT Air Conditioner
Problema con condizionatore LG LMN125HVT Air ch 67
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: LG B30AWY fault code ch
Outdoor unit PCB EEPROM failure, try removing EEPROM and refitting if removable (possible contact fault), otherwise replace PCB if the EEPROM is non removable.
thanks.
Posted on Feb 07, 2011
How do you adjust the temperature on this unit?
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. West Palm Beach Air Conditioning
Apr 18, 2016 | LG LMN125HVT Air Conditioner
Turned to the air cool setting for the season. worked at first then got intermittent flashing '61' and 'CH'. unit will not respond by remote or on the case
Condenser coil over 65°C. Check coil and filters are clean and free from debris, and airflow is OK. Check system pressures for non-condensables
Jun 06, 2015 | LG LMN126HVT LMN125HVT Ductless Air...
Error code CH 02. Since this LG model has been discontinued I am looking to repair if possible. Thermistor error but which one and can I just order a new one and simply unplug the old and plug in the new?...
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5 kOhm
at 25C. If not replace sensor.
Very easy to replace, just make sure power is off and wait 10 mins for capacitors to discharge then swap over thermistor and power up.
Mar 15, 2015 | LG LMN125HVT Air Conditioner
I have lg model LAN120HYV. Ch 67 code is flashing. What does this mean.
The CH67 code is generally related to either a fan motor failure or a blockage to the air inflow. It is recommended to check the filter, and make sure that none of the vents are obstructed. If this does not resolve the matter, then the unit may require service.
Feb 07, 2015 | LG Heating & Cooling
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
Apr 16, 2012 | LG Dehumidifiers
HO UN CONDIZIONATORE HAIER HSU-12RU03/R2,NON FUNZIONA E MI COMPARE SUL DISPLAY LA SCRITTA F22,QUAL E' IL PROBLEMA?CONFIDO IN UNA SUA RISPOSTA RISOLUTIVA.
Purtroppo, Haier non include dei codici di errore nei loro manuali proprietari. L'unico modo per scoprire che cosa significa il codice e la solutuion ad esso ? chiamare Haier clienti Sevice 1-877-337-3639
Aug 25, 2011 | Haier hwr10xc6 Air Conditioner
LG B30AWY fault code ch 12. air con unit not working. any ideas???
thanks.
Feb 07, 2011 | LG Heating & Cooling
LG LMN125HVT Air Conditioner Logo
252 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
