Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Will not turn on. Other 1 works fine. New batteries. Radio like new, little use.
The Talkabout Model T5725 pair have only been used less than 5 times. One of the pair just stopped working. the other works fine. It just will not turn on " dead as a door nail" . It has not been dropped or damaged in any way. It looks like new. I have changed batteries but no luck. Hopefully it is just a loose wire. How do I look at the inside to check for a broken connection? I do not want to junk it because it has had minimal use and is stored carefully in a canvas bag.This radio has never been wet. I would like to initially look at the circuit board to see if any loose connections but do not know how to disassemble.
email tedhaughton@telus.net (Victoria BC, Canada)
  • Motorola Master
  • 1,654 Answers
Ted, I have pondered your dilemma. When you say the radio is "dead as a door nail", are you saying it will not power on at all? If so, the problem has to be with the battery or battery connection. This radio is not a repairable radio, and there would be nothing about the circuitry inside which would be user repairable. I do think your solution might be much easier.
If you are using a rechargeable model T5725, you can try a simple test to check the charge capability of the radio. Plug in the charger to the charge port and turn the radio on. If the radio does NOT power up, then you have a battery contact problem. If the radio does power up when using the charger, but not without it, then you have a battery problem. IMPORTANT NOTE: DO NOT transmit or push the PTT while the unit is plugged into the charger. This can cause serious damage. We are only recommending this as a test of the power system.
Other thoughts concerning power would be check your battery to see it is in the correct direction. Check the contacts to see if they are clean. If not, use a pencil eraser to clean them.
If this does not help, post again with more information.
Posted on Oct 30, 2008
Motorola Talkabout MR will not transmit
From reading through your settings, they appear to be identical. Except, I am not certain what Vox 2 is, or B5 0. If the number 2 beside VOX is a setting, you should set it to off or zero. Otherwise, they appear like they should work. (VOX = voice activation, and when enabled will cause a radio to transmit when it hears a sound, voice, etc.)
If you are using an audio device such as an earpiece or headset, be certain you are plugging it in with the radio turned OFF.
Lack of transmit can also be a sign of a bad battery or bad battery connection. You might try swapping the batteries and see if the problem moves to the other radio.
If these are less than one year old, use the number in your user guide to contact Motorola for a possible warranty replacement.
Best regards.
May 18, 2013 | Motorola Talkabout T5700 AA (22 Channels)...
Motorola T5725 - Earpiece with mic wont work
A few things you might check:
1) Be certain the radio is turned off when plugging in any audio device.
2) Be certain the device is plugged in all the way. You should feel it seat, or click into place.
3) Use a device designed for your model radio. Aftermarket accessories don't always have the functionality of the OEM device.
4) Be certain you have special features such as VOX turned off on your radio.
Hope one of these helps.
Best regards.
Mar 27, 2013 | Motorola Talkabout T5420 (14 Channels)...
Canon A710IS Battery Drains Quickly
I have this issue as well, the camera seems to drain the batteries even when it is not on.
Oct 07, 2009 | Canon PowerShot A710 IS Digital Camera
New pair of new motorola talkabout distance dps radios.
can you check the PL or DPL setting on the radio that is all stadic when you receive a call?
The radio is going into monitor mode after a call is received. This is most often a PL or DPL issue.
Dec 08, 2008 | Motorola Talkabout Distance DPS (10...
The talkabout t5500 and the t5725
Hello bella-9,
The T5500 is a 2 channel radio and the T5725 is a 14 channel radio. However, the radios should be compatible with each other on FRS channels 1-14 as long as both radios are using the same Quiet Talk code. If the Quiet Talk settings are different the radios will not be able to communicate with one another.
Assuming all settings are the same (as you say) and the units are within range of each other (typically less then a mile over clear, level terrain) they should work just fine.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 16, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
152 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
