I have a Panasonic 27" color tv/dvd/vhs, about five years old. The remote control is not working. Earlier tonight my son was playing Playstation and had to put it on line 2. Typically I use the remote control to get back to the TV function. When I tried to get back to TV function using the channel button on the TV itself, it only goes has line 1 and line 2. It does not go to TV. Any ideas? Thank you.
Benimur
  • 6966 Answers
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
  • 236 Answers
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Posted on Sep 09, 2007
  • 113 Answers
SOURCE: Samsung DLP HL-R5667W
Your set has a defective color wheel. This is the noise you hear and why the set wont even come on now. The colors were bleeding because the color wheel was getting stuck and when you hit the set you unstuck it. You need to call a tech to put in a color wheel the part is about 100 dollars plus labor.
Posted on Feb 05, 2008
minteker
  • 52 Answers
SOURCE: need code for panasonic remote
Hey, here's a link to the user manual for the EUR7603Z10:
http://service.us.panasonic.com/OPERMANPDF/EUR7603Z10.PDF
Pages 7 and 8 have codes for the VHS/DVD players...
If that doesn't work, here's the manual for the DMR-E75V... http://service.us.panasonic.com/OPERMANPDF/DMRE75V.PDF
Posted on Mar 12, 2008
SOURCE: hitachi 55vf820 problem
Will not turn on. TV is pluged in its almost like a power surge. The power bar is lit so for some reason the tv is not getting power.
Posted on Mar 20, 2008
My Panasonic dvd-rv32 player (8 years old) functioned perfectly for last 8 years and I cannot get it to PLAY again. I inserted another DVD tonight (actually 3 DVD'S in case the DVD's were defective) and...
Spindle motor/laser assembly is faulty. This part is not repairable - it has to be replaced by an authorised service centre. It may not be economical via this route, since the unit is not a DVD recorder. H07 is an indication of the above issue. Cheaper to buy a new DVD player or recorder than trying to get the faulty one repaired outside warranty.
Jan 19, 2011 | Panasonic DVD-RV32 DVD Player
VHS to DVD recording
OK connect the AV Out Yellow, Red, White, OR SVHS, OR SCART, from the VCR, connect these leads color to color to the DVD's AV whatever, IN.. Press Play on VCR, and "Record" on CVD that should do it.
Jan 31, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Remote controls the tv but not the dvd/vhs player
Normaly you have a button or a switch on the r/c which allows you to control tv or dvd
Oct 27, 2009 | Panasonic Televison & Video
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Don't know how to copy video to DVD
blank disk to dvd tray....VHS in deck....PUSH PLAY ON VHS...and RECORD on DVD BURNER....if it is a burner...they weren't all burners....it has to say DVD WRITABLE or some thing in that mannern
May 10, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
Universal Remote Control cannot find code
I have the RCA RCU600D remote and i cannot get it to work with any codes listed for my Panasonic DVD-RV20 dvd player. Any ideas???
Dec 12, 2007 | Televison & Video
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
