Reverse cycle air conditioner is producing a very bad smell
  • 3600 Answers
SOURCE: I have a Haier 8000 BTU Air conditioner and it smells sooo bad.
you need to replace the air filter and shoot some fabreeze intothe ducts and clean the water pipe drian.
Posted on Jul 23, 2009
shastalaker7
  • 1515 Answers
SOURCE: My reverse cycle air con (Mitsubishi MSH 12RV) is
I would check the reversing valve. This is what switches the flow of refrigerant for Heating and cooling.There could be several other reasons that could cause it not to heat.
Good Luck, Sincerely, shastalaker7
ps Heat pumps are very temper mental, like I said there could be many things that could cause this problem, and I couldn't walk you through them all. If you have a split system, two piece unit, go to the out side unit and have some run the a/c in cool. Then after a few min. have them switch it to heat and you can hear the reversing valve switch to heat, as it will make a swishing sound.If it doesnt, the valve may be bad, no power to the coil on it, or even the coil could be burned out.
Posted on Oct 30, 2009
SOURCE: Room air conditioner smells like burning
Try cleaning the filter or replacing the filter
Posted on Dec 22, 2009
sloooo44
  • 156 Answers
SOURCE: Our brand new Frigidaire portable air conditioner
Was it new out of the box or did you buy it as an open box? Is it more of a musty smell or more of a rotting smell? Does the compressor stay on when you turn it on, or is it cycling on and off? Let me know what you find out and we can go from there.
Posted on Sep 28, 2010
heatman101
  • 43501 Answers
SOURCE: I have a fujita reverse
Have you checked the power to the unit??? The power on most of them feeds through the outdoor unit and then goes to the indoor unit...
There could be a circuit breaker tripped or there could be fuses in the disconnect box outside...
Check that you have power to everything...
If you do have power then there is a problem in the unit...probably a transformer burnt up...
heatman101
Posted on Feb 02, 2011
Is Conia air conditioner CA24001 split system reverse cycle I cannot get heat?
Sounds like either bad reversing valve or to get you going during the summer someone may have wired it to stay energized all the time which would have been a thermostat problem.
May 30, 2016 | Dometic Heating & Cooling
Bad smell coming from ac on 2005 grand Cherokee
Why Does My Air Conditioner Smell Bad? - Hydes AC
www.hydesac.com/air-conditioner-smell-bad/
Apr 15, 2015 - Does your house seem to develop a strange smell every time that yourair conditioner ... Possible reasons why your air conditioner smells bad.
Sep 30, 2015 | AC Cars & Trucks
The AC unit turns on and I can cycle through the options in order to adjust the fan speed however the fan does not start in any of the three settings. The ac unit produces cold air, however the fan does...
You say the unit produces cold air ??? where are you getting the cold air from???
If your fan does not run in any speed F1, F2 F3. and a funny smell sounds like the motor is bad
Mine works in F2, F3 but not in F1
Apr 12, 2011 | Kenmore 75085 Air Conditioner
Our brand new Frigidaire portable air conditioner emits a bad smell? what could have cause this?
Sep 28, 2010 | Frigidaire FAP094P1Z Portable Air...
My reverse cycle air con (Mitsubishi MSH 12RV) is not producing warm air (for use during cold weather). Which is likely the faulty part ?
Oct 30, 2009 | Heating & Cooling
It smells like burnt plastic after 30 min
is it new? how old is it? burnt plastic is the smell a bad motor produces. dont worry, i dont think it will cause a fire, but a fan motor on its way out will stink!
if its relatively new, return it. if not, get a new one!
Aug 05, 2009 | LG L1004R Air Conditioner
Ruud heat pump makes a clicking sound
Many thermostats have a setting to keep the fan running instead of cycling with the compressor. Check its settings.
Dec 21, 2008 | Ruud UBHC Air Conditioner
Mitisubishi Ducted Reverse Cycle AirConditioner
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Feb 11, 2008 | Mitsubishi MS12TN Air Conditioner
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
