Question about Panasonic Office Equipment & Supplies
IR-ADV 6055 error code E000020-0001 - Panasonic Office Equipment & Supplies
spinal
  • 287 Answers
SOURCE: canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Posted on Apr 20, 2008
  • 168 Answers
SOURCE: Error code E000070 0001
this is a error code for the transferf sheet either it is ripped or not turning anymore
Posted on Feb 03, 2009
  • 153 Answers
SOURCE: Error E000024-0001 on Canon iR 2870 Photocopier
the developing assembly connector has fallen off or the sensor needs replacing
Posted on Jun 04, 2009
redzventures
  • 149 Answers
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Posted on Jul 06, 2009
SOURCE: error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Posted on Aug 21, 2009
Testimonial: "very helpful"
Canon ir adv 6055 error 0748-9000
hi. that error indicates there is a problem with the flash board. you need to get technical support. there is nothing you can do to fix it
Apr 25, 2017 | Canon Office Equipment & Supplies
Canon ir adv c2030 error code e000713-0005
Error code was resolved by changing Bit 1 on SW2 located on the Finisher Controller from a '1' (ON) to '0'(OFF).
Jan 24, 2017 | Canon Office Equipment & Supplies
How to solve the error code E00001-0010 canon iR-ADV 6255i
Fuser noise and intermittent E001 code error :
The upper fuser roller section makes a noise and intermittently error code E001 occurs.
Nov 03, 2016 | Canon Office Equipment & Supplies
Canon photocopy machine model ir 6055 system error 000302-0001
Title
Error in paper front shading
Remedy
  1. Connector disconnection/open circuit of the Scanner Unit (Reader).
  2. Connector disconnection/open circuit of the Reader Controller PCB (PCB1).
  3. Failure of the Scanner Unit (Reader).
  4. Failure of the Reader Controller PCB (PCB1).
Description
Error in shading RAM access, or the shading value is either below or higher than the reference level.
Aug 11, 2016 | Canon Office Equipment & Supplies
Replace waste toner IR Adv 6055
You have to replace waste toner bottle,which is full
Jul 25, 2014 | Canon Office Equipment & Supplies
Admin password canon ir-adv 6065
i need defuilt admin user
id and password for ir adv 6065
Mar 16, 2012 | Canon imageRUNNER C5800 Copier
Error code E000005-0001 cannon ir-adv 6055
I have a problem with my machine,
Canon IR 6570 with error code E000005-0001
beg for a solution
Nov 09, 2011 | Office Equipment & Supplies
I need photo coppier "
I would recomend You the two second hend refurbished iR 3300 Copier ( B&W ) or Ricoh AF 1045/2045 and color clc 3200 for color, for the beginning and if you want later take stronger 50ppm i.e. IR advance 6055 for B&W and IR ADVANCE C2030L.
Hope that helps!
Jul 27, 2011 | Canon imageRUNNER 5000 Copier
114 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
