Question about Miele Washing Machines
Miele PW 6065 OS fault code F50
Miele PW6065 OS fault code F50. motor spins free and no volts to motor just pops up with F50 ? the machine is brand new and ran 3 times can you advise ?
SOURCE: NEW SAMSUNG WASHER WONT DRAIN.
Same thing Happened to me I found that there was a small coin caught up in the filter..
Posted on Aug 31, 2008
  • 10865 Answers
SOURCE: we are getting a f50 fault can you advise what
This is a common problem with your machine. the F50 means the motor rotor position sensor (RPS) senses no rotation. Definitely call the store and or the manufacturer and put them on notice that you have learned that this is a common problem and you want satisfaction otherwise you will go to the better business bureau and the state attorney general. Don't back down as you are one of numerous Miele customers dealing with this issue
Posted on Oct 02, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Washer starts, then shows fault code
Two things cause the dreaded F50 code. (motor)
1. The machine control
Bravos MTW6600T
http://www.repairclinic.com/SSPartDetail.aspx?s=t-Maytag+MTW6600T+-%3d%3di1469076&PartID=1469076
2. The stator
Item 17 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136402&diagram_id=1303991#d1303991
The upper cover of the stator comes in kit form and has been known to also cause the dreaded F50 code.
http://www.appliancepartspros.com/part_details.aspx?part_id=4327312&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5136402%26diagram_id%3d1303991
All of them are some what costly repair(s) in my book but cheaper than a new machine.
I have yet to change a Stator for an F50 Code.... but have changed a lot of machine controls (most often failure) and stator cover kits (occasional failure) that corrected the problem.
Just being honest. Thanks for using FixYa!
Posted on Feb 16, 2010
ladiestch
  • 19 Answers
SOURCE: Silverdragon posted on here about the Whirlpool
Tip mch back and locate the lg allen bolt in the center of the magnet and remove counterclokwise. The motor is actually a large magnet that revolve around a stator, a series of windings. Pull hard and place magnet away from any metal. Once off, remove the bolts holding the stator to the base and on the reverse side is the rps sensor. It looks like a wedge and is clipped onto the stator.
Posted on May 03, 2010
Model pw6065. Why is 'technical fault' displayed?
Hi dear. Machine display that message because,there is a problem with machine's components - drive system etc.. Which is not rectified by user. (You can check the fluff filter but you can not test the motor or electronic board.)You need to get professional help from Miele for proper diagnose and solution for it. Thanks.
Jan 30, 2016 | Miele Washing Machines
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
Ii have an F 50 fault code. What should I do?
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I get an F50 code - how do I run the test to see if I can fix it.
Sep 21, 2010 | Washing Machines
ERROR MESSAGE F50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&*(
Jun 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My kenmore elite oasis washer model # 110.2703 shows code F-50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 25, 2010 | Kenmore Oasis 27042 Top Load Washer
We are getting a f50 fault can you advise what this is
F50 = Motor Stalled
The motor is stalled first thing to check is that there is nothing stopping the motor in between the tubs under the unit at the stater motor. If every thing check OK the rps sensor will most likely be at fault. This is located under the unit to the right of the stator motor. I am sure you have researched this and have found this to be a common issue! The manufacture has come out with a kit for the f-50 f-51 error code. The kit is a new control board,wire harness,and sensor.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 02, 2009 | Miele Novotronic Premier 500 Front Load...
Whirlpool Cabrio Model WTW6400SW2 Fault F50, Motor Control board shows no sign of any damage. Could mu problem be the RPS sensor? Motor simply wont turn
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Aug 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
268 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
