Question about Panasonic Televison & Video
Herringbone pattern on tv picture. viera flat panel HDTV.
  • 110 Answers
SOURCE: Herringbone pattern
Herringbone (and other patterns) can be caused my many faults, the obvious one the tech was looking for was a tuner/interference fault.
Another common cause is a faulty power supply.
Difficult to say without having the TV on the bench.
I'm a bit suspect about the $400 - $500 repair cost though.
Perhaps try another tech?
I doubt it's a DIY repair though.
Let's know how you get on.
Posted on Jan 22, 2008
IrishDruid
  • 2712 Answers
SOURCE: Our newly purchased Toshiba -
First check if this happens in other external video source as well, like DVD/CD/VCR, etc. If it does, get the set replaced under warranty.
If it happens only with the Direct TV setup, try unplugging the set top box from both power supply and TV. Wait about a minute and reconnect. If the problem is rectified, the issue is with the setop box. Call Direct TV in this case.
Posted on May 19, 2008
bestdarngood
  • 3037 Answers
SOURCE: herringbone pattern interference
How many times is the red light blinking as this would indicate the exact problem with the tv
Posted on Jun 17, 2008
bobjrdns
  • 84 Answers
SOURCE: I bought a Samsung -
is it fuzzy with hdmi cable or just cable wire check wire and conections
Posted on Oct 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: my 52" RCA HDTV Flat Screen TV
replace the deflection board. Your model uses the ITC222A deflection PSB-260 You can get the replacement deflection board from www.tvrepairworld.com
Posted on Apr 13, 2010
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
Apr 02, 2016 | Panasonic Viera TC-P65S1 65 in. HDTV...
Why panasonic viera picture quality all blurred
If you are driving it from a laptop, and both the laptop screen and TV are on at the same time then the laptop will be sending a blurred picture to the TV.
Toggle the laptop's picture output so that only the TV is displaying an image.
Sep 05, 2014 | Panasonic Viera TX-L39E6B 39" LED TV...
Herringbone pattern at turn on clears as it warms up.
Does your TV show red, green and blue colors separated?
If the answer is yes, the problem is in the convergence circuit.
There are 2 integrated circuits (STK392-XXX) that need to be replaced by a qualified TV technician. The repair will cost around $150 or more.
Aug 13, 2014 | Toshiba 46H84 46" Rear Projection...
I have a panasonic viera tc-p55gt31 that does not have a picture
If you connect to this site and search through the TV answers, you are likely to find others have had problems with Panasonic Vieras and have gotten excellent advice from "hands-on" experts
Feb 10, 2013 | Panasonic " VIERA 55"" Class / Plasma /...
No picture and power light blinks 7 times on my viera tc-p50st30 plasma tv when it is turned on
That can be caused by either the SC or SD board. Contact the people at www.tvrepairworld.com they can assist with proper diagnosis and they also should have the replacement board
Jun 01, 2012 | Panasonic VIERA TC-P50ST30 50-Inch 1080p...
Trying to hook up PS3 to Panasonic viera LCD hdtv with HDMI cable and tv is not reading it and has no picture or sound. What may be the problem? Thanks!
hi,
ur ps3's HDMI out is a full hd video (1080p). if u r tv does not support full hd this problem can occur. do one thing. connect the ps3 to any full hd tv and go to its video setup, then down scale its video resolution to 1080i. after that connect the ps3 to ur tv. u will surely get video.
ok
Jan 11, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
Picture quality in cable mode only, watching dvd picture is
Herringbone pattern?
House stray AC 60hz signal is getting into the cable b/c the shield is not properly grounded. Call the cableguy
Mar 26, 2009 | Samsung 50 in. Plasma TV
Herringbone pattern
Jan 20, 2008 | Sony KP-61V85 61" Rear Projection...
Televison & Video Logo
174 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
