Related Tags:
This problem should be removed because:
Problem with Kenmore 24 in. 15932 Built-in Dishwasher
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
We just moved in and inherited the Kenmore Quiet Guard 2 dishwasher. Works fine but recently dishes have been coming out dirty. So I went to wash out the filter but can't find it. Dumb question I'm sure but needs answering!
Solutions (1)
Best Solution
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Suggested Solution (1)
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Source: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
Where is the filter on a Kenmore Quiet Guard 2...
We just moved in and inherited the Kenmore Quiet Guard 2 dishwasher. Works fine but recently dishes have been coming out dirty. So I went to...
kenmore 665.17539. fills but does not wash. makes
kenmore 665.17539. fills but does not wash. makes humming noise. checked pump but it is clear. what can i do
Kenmore Quiet Guard
Its now going on 3 years since I bought this dishwasher to go into my house. Well it appears for the last year my dishwasher does not dry...
I have a Kenmore model
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I...
Add Your Solution
leaks while filling up
while filling up the water leaks out the bottom
Water won't swoosh around
Hi. My Kenmore fills with water, heats up and drains but it won't swoosh around. Is this something I can fix?
Fix-O-Meter
912
912 people viewed this problem
- 1 person found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Kenmore Dishwasher Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
