Question about Fargo DTC550 Thermal Card Printer
Printer shows error on card hopper lift. - Fargo DTC550 Thermal Card Printer
3 Suggested Answers
desertrat144
  • 22 Answers
SOURCE: My printer has an error on the screen and I don't
Go to the manufacture's website to see if there is an owners manual hat ou can download; if that doesn't work Google the manufacture name and problem, you'll get directed to User's Groups, and should (hopefully) get the answer there.
It's a bummer having to use that approach, but there's a load of internal things to be messed up, and that can be done too easily.
I hope this works out for you.
Posted on Sep 13, 2009
  • 11 Answers
SOURCE: Resolving a Card not fed error (Cards will not feed off the Hopper)
That model printer is notorious for slipping the card feeder drive belt>
Posted on Jun 03, 2010
Why my DTC550 is saying Error Calib Hopper Sensor
On the Printer, follow these steps :
"Menu" > "Setup Printer" > "Sensor Calibrate" > "Cal Hopper Sensor" >Then press "Select".
Oct 17, 2014 | Fargo DTC550 Thermal Card Printer
Error code 24:08
Hi There,
The most common reason for General Error 24:08;
Hand Feed Mode is ON. (only time this error is shown)
The printer expects the card to be fed from the manual card feed slot at the front of the printer.
If the card is 'manually' fed from the rear of the printer (with the rear card hopper removed), then this error message will be displayed.
Hope this helps,
Kind Regards,
MC.
May 06, 2014 | Magicard Office Equipment & Supplies
Sticky back card static causing them to stick togeather and not feed from the hopper
Hello Richard,
Sorry for the delay in replying to your request.
Feeding cards (especially self-adhesive types) from the rear hopper, can sometimes be frustrating. You have done the right thing by separating the cards (this applies to all cards - just fan down both sides like a dealer would with a pack of cards). This important.
Please try the following additional trick though;
Remove the rear hopper.
On the front panel, select Menu -> Test Card -> Yes (to confirm).
The rear hopper roller will start to rotate.
Take a fresh cleaning card (from the cleaning kit - 3633-0053) out of its wrapper. It MUST be damp.
Fold it into a loop and manually hold the cleaning card against the hopper roller as it turns (with gentle hand pressure). The idea of folding the cleaning card is to prevent it from being accidentally dragged into the rear of the printer.
After about 12 seconds, an Out of Cards 02:00 error will be displayed. Press Retry.
Turn the card over and repeat until there are no Black marks left of the cleaning card. Repeat as necessary moving to a fresh part of the cleaning card each time.
If the card should accidentally go too far into the printer, a Card Jam 06:05 error will be shown. Just open the lid, and close it again to clear the card jam error. The sequence will carry on from the previous stage (the hopper roller will start turning again shortly after closing the lid).
Once you are happy the roller is thoroughly clean, on the next Out of Cards error, press Cancel.
Discard the cleaning card which will probably have dried out by this point. Replace the rear hopper.
Card feeding should then be trouble-free.
If the problem should persist, contact your local Magicard support centre.
Kind Regards,
MC.
Nov 21, 2013 | Magicard Rio Pro Single Sided Photo ID...
Card hopper lift erorr
card hopper lift problem the printer is tell me not ready i dont understand it speaches but i can tell you, please can you send the solution for me...... my email address: godfrey_cole111@yahoo.com
Dec 17, 2009 | Fargo DTC550 Thermal Card Printer
My printer has an error on the screen and I don't have an owners manual. It says "Attention Card hopper lift"
Sep 13, 2009 | Fargo DTC510 Card Printer
The printer shows head lift error ...so ..how can I solve this problem ?
I had the same problem with my fargo dtc 550.
I changed the "O" Ring rubber attached to the printhead and that solved the problem. No more head lift errors.
Jul 02, 2009 | Fargo DTC550 Thermal Card Printer
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hi i have fargo dtc525 card printer i am using that printer scince 1 year, now not working error massage HOPPER 1 EAMPTY this type of message showing please tell me solution.
hopper 1 empty means that you do not have any cards in it. The printer has 2 hoppers, and your program maybe defaulting to hopper 1. Select hopper 1 and cards to it and that should solve the problem.
Nov 30, 2008 | Fargo DTC525 ID Card Printer
Make sure that your hopper card thickness guage (located on the right side of the hopper) is set to 30 ml or above if you are using standard 30 ml PVC cards. You may also need to clean the printer with a Fargo printer cleaning kit for this printer.
Also check to make sure to check your PVC cards. Sometimes they have too much static and can stick together not allowing them to feed. Fan the cards before placing them back in the hopper to make sure they are not sticking. In this process, try not to touch the printing surface of the cards as oils from skin will cause defective printing results.
For more id card printer tips, visit our technical assistance blog at www.safecardid.com/blog.
Nov 05, 2008 | Fargo DTC525 ID Card Printer
Card hopper jamming
Could be that your cleaning unit is not installed or is old. Or, it could be too few cards in the card hopper. You could apply a little weight to the cards in the hopper to see if that helps. And/or try changing out the cleaning cartridge.
Oct 04, 2008 | Fargo DTC520 Thermal Label Printer
Fargo DTC550 Thermal Card Printer Logo
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
