Question about HP Scanjet 4890
No picture Switched Scanner from a Computer with an xp operating system to a computer with a Vista operating. With the vista System the scanner produces only black pictures. The light does not come on. .
  • 9 more comments
  • Tiroler Oct 23, 2008
    The scanner produces only black pictures. The light does not come on.
    I have the vista driver.
    yes this correct HP4890
    I have already done, that the light does not come on with xp
    The scanner was nerver mouved it was only reconected
    I do not understand what you mean with your suggestion "First try to scan from the windows photo gallery ...."
    The scaning process takes place but without light no picture
    tell me at least where is lamp located and how to get to it
    Are you still there ? If so give me Somme specific advise.
    I am going to bed. I hope to hear from you in the morning.
    Let me restate the problem:
    The scanner scans properly but because the light does not come on I have a black image. I need to know how to get to light.
    It appears you know less than I do. Your dishing out platitude.Don't advertise yourself as expert you are a fraud,
    I have stated before the vista driver is properly installed. Forget the driver we have Hardware problem. You comment: the light is under the assembly .... "is completely useless.
    Guru:
  • 558 Answers
I need some clarification, as you mentioned in very first comment switched from XP to VIsta: Was it working fine in XP??
Is anything gone wrong with the scanner during this period (may be felt down, or wet etc. Try to remember that and let me know)
As you mentioned in fourth comment: "Light not coming" -- are you talking about scanner Bulb or indicator??
Since upto last I figure it out the Scanner Bulb gone damage somehow, and need to replace..
For further support and troubleshooting please visit this link:
HP Scanner 4890
Posted on Oct 23, 2008
    Scholar:
  • 136 Answers
If you have the installation cd of your scanner please readf on the jacket of your installation cd that wheather it supports windows vista or not .because if it not supports windows vista it will show this types of errors . for the compitable drivers for your scanner to support vista click this link and download http://www.microsoft.com/windows/compatibility/Details.aspx?type=Hardware&p=ScanJet%204890%2048Bit%204800x9600dpi%20USB%202.0%20PC/MAC&v=HP&uid=L1952AB1H&pf=1π=8&c=Printers%20%26%20Scanners&sc=Scanners&os=64-bit
.and if you have the proper drivers for your scanner which supports vista. then it could be the problem of your scanner with the white colour cable broken or got slightly loosed or the scanner bulb is faulty. take it to the repair center it would cost you near about $50 to get it repaired. but before taking it to repair please check wheather the drivers for the scanner which you r installing are supporting vista or not.
thanks. keep us all updated to help you further.
    Genius:
  • 1,226 Answers
Thank you for using fixya. The most effective way is to consult your vendor about the problem of the scanner...Its either factory defect or system compatibility.
melnavz
    Sergeant:
    Champion:
  • 435 Answers
Hi, from your problem description, this is what I assume.
Even after you tried installing the vista driver, its not working.
When you say the scanner works, I assume that the scanner head (long rod like thing) moves but without light.?
I hope you used HP scanner software to try scanning.
Well, the troubleshooting part. Since the light does not come on, can you try shining some light onto it when it scans ?
You can also try leaving the scanner cover open when it scans and see if the scanned picture is still black.
If so, then the problem might be with the hardware. In that case, you need to get it fixed by HP itself.
    Sergeant:
    Champion:
  • 331 Answers
The light does not come on that could simply mean that the scanners 's drivers r not correct
did u install the drivers for this scanner(the drivers have to be for VISTA)
there should be o problem with the light if the scanner was not moved....
install the new rivers and ur scanner..........
the light is situated right below the assembly
  • 3,037 Answers
It could be a random instance that when you switched, the scanner also took a dump. Can you try using it on the computer with xp and see if it still works. If it does, then we will look into a problem with the computer with Vista, if it doesn't then the scanner is done and it is cheaper to get a new one rather than have this one repaired as hp doesn't generally sell parts and I doubt you can find the part anywhere anyway.
  • Benjamin Patri
    Benjamin Patri Oct 23, 2008
    Can you please let me know if the scanner still works with the computer with xp by hooking it up again? Like I said before, this will narrow down the problem and if is a part on the scanner that randomly went, then it will be cheaper to get a new scanner but in order to help you, I need your help by answering my question
  • 905 Answers
The fluorescent bulb is not lighting because there is a connection problem in theunit or the bulb itself is burnt , and no software is going to fix it
if you just bought it I would take it back or have an electronic repair shop replace the bulb or fix the bad connection which ever one it is
electech
  • 6 more comments
  • jason Oct 23, 2008
    the light is not working and not be cause of a software or operating system issue
    it is burnt or not connecting and needs to be replaced or check for bad connection. every time the scanner scans the light should be on , but its not so something is wrong with the scanner
    electech
    the lamp scrolls accross the bottom of the glass , so the unit will need to be taken apart
    the problem will be getting another lamp , do you know where or how to get it?
    it is possible that from it moving back and forth that the plug to it came unconnected with the light but it is still in place , but if not the scanner element(which has the lamp in it) will have to be replaced
    these scanners are not easy to take apart , there are philip screws that hold it together and will be seen in the holes in the bottom and in the back of the scanner , disasembling the unit will take removing piece by piece untill you can finally get into the inside where the lamp is, you will have to look for all the screws that are holding it together
    i will hang out to assist you when you get stuck on something , are you able to take a photo if needed , so i can see when and what youget stuck on?
    there is a wire strip that looks like this , try and push it back in and see if that helps otherwise the wirestrip might be broke inside or the bulb is burnt
    let me clarify , you have to take it apart!
    and this is not woth a couple of dollars to me , I get a heck of alot more repairing them!
    good luck on your scanner
    and you wouldn't be here if you new how to fix it , let alone how to take it apart!
    good bye
    here
  • 507 Answers
Try this vuescan version for vista
    Genius:
  • 2,035 Answers
  • 1 more comment
  • Anand Kumar
    Anand Kumar Oct 23, 2008
    Check all the power and usb connection to scanner and computer , if possible try to connect the scanner to another ac mains and power it on and check .............
  • Anand Kumar
    Are you getting the power on the scanner ?
  • Anand Kumar
    IF the scanner light rod does not move then its scanner assembly failure, you need to change the scanner assembly in the scanner ,if you remove the glass plate you can access to scanner light rod , but first check if the scanner is power on , if its not on then you need to try different AC mains even this fails then power adapter is not working you need to change adapter ...IF there power in the scanner but only the scanner light does not move then its a hardware failure ....
    Good luck...
  • 4,472 Answers
First I need to know if you can go back to the old system and see if it is still working fine. The unit may have been damaged in the move. Did you make sure to lock the scanner while moving it, and unlock it when using it? Once I have more information I can assist you further. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
  • Lee A.
    Lee A. Oct 23, 2008
    have you tried downloading the latest driver from hp.com and uninstalling and reinstalling the scanner?
    Can you try the scanner on an XP machine to make sure it is software related and not hardware related?
    Thanks,
    Lee
  • HP Master
  • 6,487 Answers
If possible can you try to connect the scanner back to the XP machine so we can check if the light will come on because if the light will still not come there's a possibility that some parts of the scanner is bad or not aligbn properly, also try to install the driver for vista....
  • Mark Gil
    Mark Gil Oct 23, 2008
    So if the light wont come on even when conencted to XP so this is not a problem with the driver , you may need to open the scanner and check the internal parts of it that may got loose.....
    Master:
  • 538 Answers
I see that the model number listed is the scanjet 4890. can you confirm this is accurate. having difficulty finding driver information.
  • 360 Answers
You need to totally remove the driver and scanner and reinstall driver without scanner connected ....... justuscc
  • 749 Answers
You will need vista drivers found here :
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=446436
download them to your desktop and double click and follow the prompts
Hp scanjet 2400 - system is format but Scanner CD is missing how to install scaner software
Just goto th hp site and enter the model of you scanner, download the drivers. Don't forget to select your systems operating system (XP, VISTA)
Thanks
May 15, 2010 | HP ScanJet 2400 Flatbed Scanner
Will not work with Vista operation system
Correct. There is no easy solution for this issue. Several of the "older" scanners are no longer supported through the Vista operating system. Why not purchase a new multi function printer, scanner, fax and copier unit.. you will not locate vista drivers either online or from the manufacturer and without them, the scanner will not function. Alternatively, you could also roll back or re-install Windows XP operating system..
Nov 02, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
My operating system (Vista) is not supported by installation of plustek scanner OpticPro U12B
Unfortunately you have a compatibility issue. Some devices simply won't work with the way Vista is structured. The only options you have here are to replace the scanner with one that is Vista compatible, or change your operating system to windows XP, which supports your scanner.
May 06, 2009 | Office Equipment & Supplies
Astra 3400 Driver for win vista
Simply do this.
Start/Programs/Accessories/System Tools/Compatibility Wizard
Set the machine for XP or Win 98
Jan 12, 2008 | Umax Astra 3400 Flatbed Scanner
Drivers for Vista
With the Computer.
Go to Start/programs/accessories/system Tools/Compatibility and attempt to reset the computer to the Windows mode the Scanner was made for.
Be aware however that Scanners made for use with Win 95/98/ME operate under DOS commands and 2000/XP/Vista work on the NTFS system so there is a hardware not software problem.
You will I feel wind up buying a Vista Compatible Scanner
Nov 11, 2007 | Agfa SnapScan E25 Flatbed Scanner
Umax Astra 2200 scanner needing to run in Vista
Hi, The Umax Support/Download (http://www.umax.com/download/index.jsp) do not have any patch/updated drivers for your scanner compatible with Vista. If the only issue that you would downgrade your operating system back to XP is because of the canner, it may not be necessary. It is possible to dual both allowing you a choice of Vista or XP. This is better explained at (http://apcmag.com/5485/dualbooting_vista_and_xp). This way you will retain the use of the new features of Vista in your new computer and yet when necessary make use of your previous devices that will only run in XP. Hope this be of some help/idea. Post back how things turn out or should you need additional information. Good luck and kind regards.
Sep 28, 2007 | Umax Astra 2200 Flatbed Scanner
Acer Scanner 310P Drivers for Windows Vista
I have a Acer scanner with mirascan 3.40 it does not work in winxp. can u help me to solove this problem. My Email Id
manaspattnaik1@gmail.com
Apr 26, 2007 | AcerScan 310P Flatbed Scanner
HP Scanjet 4890 Logo
115 people viewed this question
Ben Johnson
