Question about Sony KP-53S70 53" Rear Projection Television
SonyKP-53S70 No power, red led blinks
  • Any Guy
    Any Guy May 11, 2010
    How many times does the red light blink?
I will check how many times the led blink when I get home tonight. won't be until after 10:00 Central.
Posted on Oct 24, 2008
Sony 53s70 rear projection tv
Using remote control might not turning on the TV. Can you please try to use CH+ or CH- buttons on TV side. If issue still persist consult to a qualified hands on technician as Issue might be internal power supply related.
Good Luck
Jan 01, 2008 | Televison & Video
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
Epson R230 with green led and red led blinking
This is general error of the printer. When you have to change the new mother board you should be initialized it then it can be ready mode. When you try to initialization you need printer printer adjustment program. You can batter find out from google & write down EPSON Stylus R230 Printer Adjustment program or ink reseat program.
Jun 12, 2013 | Epson STYLUS R230 InkJet Photo Printer
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
May 01, 2010 | Sony KP-53S70 53" Rear Projection...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
My Tv made pop sound and now the red lifgt blinks 4 times.. And no picture. any idea what I need to do and the cost?
Hi,it sounds like you lamp went bad.If your tv is between 2-4 yrs it will be the lamp that needs replacement,The red indicator is indicating there's an issue with the lamp.Try this websites discount-merchant or, discounttvlamps, They carry the original brands.
Oct 05, 2009 | Sony KP-53S70 53" Rear Projection...
Can't find the cooling fan
Unfortunately, you apparently got information from someone who has not had training on your set. A 4 flash on your set indicates a vertical stop, meaning that the vertical drive circuit has shutdown. Possible causes are a bad vertical drive or vertical output IC. I can't be more specific because I would have to check a couple of things, starting with the 135 volt power supply line to see if it is coming up. You can stop looking for a cooling fan because this set does not have one.
Nov 10, 2008 | Sony KP-53S70 53" Rear Projection...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Sony KP-53S70 53" Rear Projection Television Logo
141 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
