Lost my manuel for 21o ccc - Office Equipment & Supplies
  • 507 Answers
Sorry, without the brand i can't help you.
Posted on Oct 25, 2008
I installed recently HP officejet Pro L7480, but hP solution center failed to detect any device and closed. the officejet also failed to scan - error message: No scan option
Hi There, This is a known issue with this device. Please follow the below steps to fix this issue : Try to do a complete uninstall
*first step*
-run installation media (CD / Download) software
-select uninstall and on the process, select uninstall all hp softwares associated the with the device
-after uninstall , select restart later to reboot the computer later
-go to start > control panel > add/remove programs (XP) programs (Vista)
-uninstall any existing HP softwares (note: for hp computers, skip this process)
-restart later
*2nd step*
-open contents of the installation media
-if you're using the installation CD. go to my computer, select the drive which has your cd in (eg. E:/ , D:/ ) right click on the icon and select open / explore.
-if you're using a downloaded software, click on start and click on run (XP) startsearch (vista), on that box, type in the command ( %temp% ) and press enter. it will open up temporary files folder.
-locate the file that starts with 7z (eg. 7z001cs1) and open it and now you are in the contents of the installer
-on the contents of the installer, locate UTIL folder and open it then locate CCC and open it as well
(note: check your operating system if it is running on a 32-bit or 64-bit . you can check it going to start>control panel>system)
-on CCC folder , locate uninstall L1 (for 32-bit) uninstall L1 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
-on CCC folder , locate uninstall L2 (for 32-bit) uninstall L2 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
on CCC folder , locate uninstall L3 (for 32-bit) uninstall L3 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later (repeat uninstall L3 steps for 3 times)
**********important**********
(do not run uninstall L4)
contiunued in the next post ..............................
Nov 14, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I lost my Manuel and when I try to print something
Here is a download page for your manual:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=8046
as for the settings........
Go to0 the start menu, select "printers and devices"
select your printer, select printer preferences,
and change the setting from the menus.
There ya go!..........Please remember to RATE ME. Thank You.
Mar 08, 2010 | Canon BubbleJet i550 InkJet Printer
The status of my printer says error. How do i fix it.
insert the software cd, and brows the cd. there will be an UTIL folder inside the cd,inside util there is a ccc folder,and inside ccc folder we have uninstall L1.exe file.
unplug the printer usb cable first and then double click on the uninstallL1.exe. it will uninstall the basic driver from the computer and then restart the computer and printer.before that ple take out the cd.
then try to do an add a device by inserting the software cd of the printer.
Oct 22, 2009 | HP Photosmart 3210 Printer
It says o HP product detected
If you have the CD then insert in and do a right explore, then look for a folder named UTIL and under that u will find CCC and under ccc u will fine something called unintsalll2.bat just run that file
then restart the computer and then insert the CD and follow the instruction to get it fixes
Oct 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Image won't scan
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tonl-i-21
Apr 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Scanner not set up
Have to uninstall and reinstall full software solution. First uninstall using the hp program, then use add/remove program uninstall Image zone, extended capabillities and HP update, restart pc and search for scrubber in Hp software it's in utility folder, ccc, doubleclick it to work. then you are ready to reinstall the fully software.
Nov 17, 2008 | HP LaserJet 3050 All-In-One Printer
Unable to clean?
Heres the mauel for the MFC-210C printer.
http://www.brother-usa.com/manuals/default.aspx?PRODUCTID=MFC210C&ProductGroupID=5
You can clean the outside of the printer and the paper handling mechanisms with a mild cleaning solution and a lint free cloth. To clean the insdie of the printer, use a HEPA vacuem and follow the manuels recommendations.
Nov 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
29 people viewed this question
k24674
