Question about Home Security
My honeywell 5800pir-res motion sensor does not work properly
I have to walk right up to the motion sensor for it to detect me
2 Suggested Answers
  • 80 Answers
SOURCE: Simon XT panel does not want to learn motion sensor
try learming the sensor in by removing the back and actavation the tamper switch of the unit. also make sure that the unit is not already learned into the unit and if all else falil default the panel and start over.
mj
Posted on Sep 07, 2009
New apartment with A honeywell ademco 4110xm. I connected power and got master code. I get CHECK 05 and ALARM 06. Typing the code and OFF disables the ALARM 06 error, but Check 05 remains. Any help?
It is telling you that a zone is not working properly or is open. Ex. door not shut, window not shut. Something moving in front of a motion sensor. Fin out what zone 5 is and that is your problem for arming. Could be a battery if this is a wireless system.
Jan 18, 2016 | Honeywell Home Security
Why is the LED light completely off after the walk test and lockout time?
Yes, it works normally. Things have evolved in the technology of security systems and now it is standard to have any LED turned off on any motion detector (the LED's are now used for walk-testing only), the standard DSC and Honeywell wireless motions also do the same thing.
  • This is a normal function for your motion detector. It's also a great power saving function since most of the current draw on the batteries is when it's transmitting a detection signal so if you're home and moving around it will only transmit every few minutes instead of every second, saving on battery life significantly (up to 5 years on average) but after the 3-minute lockout the passive infrared scans continuously until it transmits another motion signal.
Reason: most burglaries are done by someone who has been there before, if they see the LED then they know the motion will catch them moving in that given spot, then they can "map-out" where it's safe to walk (where the LED doesn't light up) for when they plan to return for a robbery.
You can also make this device "more sensitive" by moving the jumper pin position by the right side battery and having the back mounting plate mounted using the bottom screw presets so it faces slightly downward instead of straight forward.
Helpful tip: Change the batteries every 4 years if you're using Alkaline (dead or not) since the detector was engineered "too energy efficient" and the batteries actually leak and corrode the interior PCB at about the 5-year point on about 15% of the detectors with factory original duracell batteries (from what I've experienced in field service).
Apr 06, 2015 | Interlogix GE SAW Wireless Indoor PIR...
As per request. re: reset/fix indoor motion detector.
on all the Honeywell or Ademco wireless motion detectors I have worked on the light will not come on with the cover in place, it is set that way to conserve battery life. If you want to be sure it is working properly arm your system and wait at least 4 minutes before walking in front of he motion then walk in front of it and see if it trips the alarm.
May 05, 2014 | Honeywell Ademco Apx32en Alarm System...
Battery in ademco 998pi
It could possible be your main battery in the panel.
Apr 11, 2014 | Honeywell 998pi 998 Motion Detectors Pet...
Unclear directions on motion detector installation
Contact Honeywell co directly they are great people and great cust service and will walk u through the process
Feb 05, 2014 | Honeywell Home Security
PIR Sensor problem
This is normal. it takes several minutes after power up to adjust to the environment that it is in. Then the motion will only transmit a signal to the alarm panel every few minutes. This is to conserve battery life. Let it sit idle for more than 3 minutes after arming (do not trip the sensor during this period). Afterwards, the first trip should be instant and that should be all you need.
May 28, 2013 | Honeywell | Ademco LYNX Plus LYNX Plus
I have this light for 2 years with no problems at all. recently, it seems that the "left side" of the sensor stopped working. (If I walk right in front or in the right side, the lights will come...
  1. Locate the sensor on the motion detector. The most common problem with a motion detector is a sensor that is obstructed or dirty. Remove any dirt, grime or anything else that may be blocking the view of the sensor. If you need to actually touch the sensor itself to clean it, use a soft cloth or cotton swabs.
  2. Determine if the motion detector has electricity running through it properly. Connect an electrical meter to the wires from the sensor itself. If electricity is indeed running to the sensor, you likely have a broken senor. If there is no electricity making it to the sensor, your motion detector has an electrical short. In the case of an electrical short, you will need the help of a professional electrician to fix it.
  3. Visit a hardware or supply store to buy a replacement sensor
Thanks for understanding.
Nov 16, 2011 | Heath Zenith All Metal Motion Sensor Light...
How do you work the pedometer
Switch on, set up the timeframe you want it to record your steps, press start and have it in your pocket on your belt, when you walk. The motion sensors will detect the amount of steps you take within a given time period, or if you have it on all day, it will take your whole day's walking steps.
Vote for me if this helps thanks.
Jun 28, 2010 | Sportline 345 Electronic Pedometer
STYLE AUTO DUAL GARAGE LASER PARKING (motion detection)
Yes the unit will turn on at any motion. There is no way to turn the motion censer of or adjust it for a certain distance.
Jan 28, 2010 | Garage Door Laser Parking Guide
Dsc sensor not operating properly. I want to change it, is this very difficult? Thank you.
You don't mention what type of sensor. I assume it is a motion detector. Before replacing I would strongly suggest you first remove all power from the system by disconnecting the backup battery inside the control panel then pull the system's power transformer which should be plugged into an electrical outlet nearby. You will know that all power is removed by looking at the keypad - all lights on the display are off. Next remove the motion detector's front cover. Some detectors have a small screw on the bottom so that when removed the cover pops off. Others need to be opened using a flat blade screwdriver and prying off the cover. Once the cover is removed there should be a 4 conductor wire that is wired to a series of terminals. Observe the polarity of the wires, disconnect them and remove wall mounting screws. Install new unit. Be sure when wiring to connect power wires correctly. The 4 conductor wire should have a red (positive) wire and a black (negative) one. Connect the red to the + or pos terminal and the black to the - or neg terminal. Read the instructions that came with the new unit if in doubt. When finished plug the power transfomer back in then reconnect the battery (in this order). If power is connected properly the motion detector's red walk test light (indicating motion) should light whenever you walk in the protected area. Also make sure the system recognizes motion by first closing all protected areas such as windows and doors to get a system ready or green light indication on your keyad, then walk around the protected area. A properly working detector will show you a fault on the keypad everytime the system senses motion.
Sep 11, 2009 | DSC Home Security
Home Security Logo
101 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
