Question about Dell 3010cn Laser Printer
How do i override dell ink toner on a mfp 1125
  • wanda dreher Feb 09, 2012
    we purchase a generic toner for our dell printer and it is showing up as invalid toner or no toner found
2 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: Dell Mono Laser MFP 1125 says no toner found
double check the one you installed to ensure it was installed correctly. You can do this by removing it with the power turned off then reinstall it. Try to power it back on.
Spanish speaking available for all problems Thank you for allowing us to help, please respond with further questions and concerns
Posted on Jan 09, 2011
HELP! My 1125 Dell printer is giving me problems! I installed the ink cartridge, as I have done MANY times before, but the green handle is blocking the door from closing. It seems as if it is all the way...
I have had the same problem. I dread trying to change the toner cartridge because it just doesn't fit once you take it out. There is something really wrong with this printer. I am not incapable of changing a cartridge. But this particular configuration doesn't work right once you take the tray out. In fact, it is so difficult to get the green handle to fit back in properly, I'm pretty sure that it is responsible for the fact that the paper feed tray doesn't work anymore. I hate this printer. Really.
Mar 08, 2011 | Dell 1125 All-In-One Laser Printer
Dell Mono Laser MFP 1125 says no toner found invalid toner it just flashes the above i just added a new cartridge
Jan 09, 2011 | Dell 1125 All-In-One Laser Printer
My Dell MFP 1125 was out of toner and before I could replace it, it powered down one day while I was away. I have tried unplugging it from the outlet and even removing the power cord, but it will not power...
On mine, after some trial and error, I found that if you DISCONNECT the unit completely from the AC outlet for 5 or 10 minutes, then plug it back in again it works.
However please check these things:
1)the power cord wire must be faulty.try replacing that power wire. 2)the power cord wire must not be connected properly either to the electric outlet or to the back of the printer.
3)the electric socket in which u r trying to connect the power wire must be faulty.check out in any other socket.
4)or it could be the short circuit in the main board of printer.if that is the case then it will be very much costly to get it repaired.
Sep 02, 2010 | Dell 1125 All-In-One Laser Printer
I can not receive faxes on my Dell MFP 1125
Hi, I have Dell 1125 All-in-One Laser Printer. I can send faxes by going to fax option and dialing the number.
How can I set it up to receive faxes? keep in mind that I have only one phone line which I use for both phone and fax.
How can I set the ringers in a way that for example at 4th ring goes to answering machine and at 6th ring goes to fax?
I really appreciate it.
Need help fast :)
Mary
Aug 03, 2010 | Dell 1125 All-In-One Laser Printer
Invalid toner or no toner available
These toner cartridges have kill chips on them that are essentially just page counters. It sounds like the chip is either defective or missing. Some low cost refillers will either leave the original on or us very low quality replacements. I would return the cartridge to whoever you bought it from and be sure to purchase a quality refill or original next time.
Feb 16, 2010 | Dell 1125 All-In-One Laser Printer
Low toner sensor on Dell 1110
First of all, you should not try to manually override these components.
When you do this it may cause other problems, minor or major in a mechanical or electrical means.
Some of these machines have internal counters in the main boards.
They may work with the sensing of low level ink but also count the amounts of copies printed.
There are some of the machines that use a "Weighted" type sensor. Others use a photo eye sensor. If it is a weighted type, usually a brass looking type, extra precautions need to be taken. If they are even touched by someone's hand, they can create a static discharge to the sensor and burn it out very quickly.
The best things to do, is just run the machine the way it was designed to work.
Oct 17, 2009 | Dell 1110 Laser Printer
Dell laser printer MFP 1125 paper tray removal
I just did this 5 min ago. The tabs that hold it on the machine have cams that hold it in. just squeeze the tray lightly at the tabs and it slides right out.
May 31, 2009 | Dell 1125 All-In-One Laser Printer
Dell 3010cn Laser Printer Logo
60 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
