Question about Acer Aspire 5670 Notebook
Computer freezes on boot up
I have tower with problem where i moved it from one table to another,feet from one to other,upon boot up mouse would no work,it would lite up though,keyboard would lite up.pass word protoect sign on im stuck nothing worked,opened up,full of dust ,blew it out,rebooted mouse works few seconds till boot up,then keyboard lites up beeps 1 time lites out mouse freezes,stuck.changed memory sticks,either mouse will work and not keyboard or vise versa,still cant get in to check,upon boot up tried to enter systems f8 keyboard wont respond to touch keys,im stumped,did nothing unusual no new programs either.any suggestions?/ its an "e" machine with xp sp 2
  • 520 Answers
Make sure the mouse and keyboard are in right connections...if you look closely youll see icons next to ports.
try without mouse at first start up ,load windows and use key with windows logo on it to access start and scroll to shutdown tab and restart...plug in the mouse before restart.
if logo tab isnt assigned press ctrl + esc to access start menu.
Posted on Jan 24, 2009
Dell Dimension 3100 won't boot; keyboard fell off the table onto the tower; am getting 1-3-2 beep codes. Is this fixable?
Just because they hit the tower should not have hurt anything.
But, you should turn it off, pull the power plug, then hit the power button, then again and make sure the lights don't turn on or flash.
This make's sure that all the power is gone from the motherboard.
Before you touch the inside, make sure you touch metal, so you don't static shock the motherboard.
Now open the the side up. I would remove the two power connectors, one should be a 20-24 pin and another 4 pin.
Reset them to make sure they didn't come lose.
Check the HDD, hard drive plugs, fan plugs, the CPU fan plug.
Then check the monitor connection, and any on the back.
Try the monitor on another PC, or a monitor from another PC on this PC.
A hard shock to the power supply unit (PSU ) can kill it, it can still turn on the lights but not have the voltage to run it.
If you do all this and are safe and careful checking inside and out, then you might have to take it to someone who can test it.
You can also download the manual so you know what it looks like inside the PC and what the motherboard looks like and how you would set it up when new.
Good luck.
Mar 31, 2013 | Dell Dimension 3100 PC Desktop
Intel pentium 4 computer ' smetimes when I move mouse page moves
well pentium 4 is one of the best processor and as you say that it is of ten years old it seems it had worked for more than what it was expected of so there no loss if you go to buy a new PC.
good luck.
Jan 05, 2010 | Intel inside Pentium 4 P4 System Case...
Freezing or Jumping Mouse Pointer
This could happen if the PS/2 connector on the motherboard is defective, or if there is a failing component in the PS/2 circuitry on the motherboard.
Could also be due to loose solder points at the PS/2 connector.
This needs to be checked by a qualified technician.
Apr 12, 2009 | Foxconn 661MX Motherboard (FOX661MXMB)
G5 Graphics Card Freezes or begins to show lines on display
Since you are able to see your mouse pointer move, the display is refreshing so the problem is with something other than the graphics card. Generally software / OS related.
So assuming you aren't experiencing a hardware failure try the following...
Boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot from the CD
If so run disk utility from the CD and repair the disk as well as permissions. If there are any errors repair again.
If this is successful your computer "should" be repaired. If it is still freezing, use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Cheers
Mar 02, 2009 | Apple iMac G5 Desktop
It will boot up to the windows screen and freezes. There is no mouse control.
WIN XP ONLY!
Upon booting, beofre Windows Logo, press F5 key to get computer to boot into SAFE MODE/Administrator. See if you have mouse control under this mode. If yes, then there's a good chance that the mouse is OK .
once in SAFE MODE and are able to regain mouse, the chances are good that you can just restart the computer and everything will return to "normal".
Suggestion #1: reboot computer to NORMAL after having sucessful SAFE MODE mouse test.
Suggestion #2: see if you have a recovery point (system restore) before the mouse issue came about.
Jan 15, 2009 | Computers & Internet
Logitech Mouse
Where do you have the transmitter sitting? If it is below a desk (i.e., sitting on top of the computer tower, etc.) it may not be emitting a strong or consistent signal. Try moving it within a clear line of sight to the mouse. If that doesn't work, it could be a problem with the mouse itself and need to be replaced.
Hope this helps, let me know
~ Genie-Us IT
Jun 25, 2008 | Logitech Computers & Internet
PM2F 100005615 Mouse
When you start up, have to mouse on the one that freezes and then switch off that one. (turn on the one that freezes first and have the mouse set it. then once it is on boot the other one and then switch mouse.
Nov 26, 2007 | Computers & Internet
KVM freeze, mouse and keyboard failure upon keypress
When ever trouble shooting a KVM that has a problem with one computer always swap the cables at the computer end -- that will tell you if you have a computer or KVM issue.
Nov 07, 2007 | IOGear MiniView GCS62 2-port KVM Switch
Acer Aspire 5670 Notebook Logo
289 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
