Question about Garden
Govenor spring correct fitting 375 sprint - Garden
  • 1 more comment
  • christieleep Feb 09, 2012
    photo of fitted springs
    i would like to know what correctly fitted govenor springs look like 375 sprint
    someone incorrectly modified the spring tension
    Sergeant:
  • 316 Answers
Hello, If you go to briggs and strattion.com model parts search or manual,you will need engine model number,to find your parts or engine illustration,hope this helps. @@
Posted on Feb 20, 2012
Push mower revs too high with throttle just open (or a little higher with the throttle opened more). Revs stay high until throttle reduced to cutout point.
are you sure you have the right spring fitted?? and have you tried adjusting the spring tension? you can do this by bending the arm that the govenor spring attaches to as seen in this picture
Feb 18, 2015 | Garden
How do I correct the motor from pulsating
Sounds like the govenor is messed up. Check the springs on the carb linkage, maybe one of the little springs has come off or broken.
Oct 03, 2014 | Champion 3500/4000 Watt Portable Generator
How do you assemble the two springs on a sprint 375 briggs and stratton ?
The ends of both springs hook at the loop of the metal linkage connecting the governor vane and throttle shaft. The other end of the small spring hooks onto a small upright plate approximately 1 inch towards to the front of hooked end of the spring. The longer spring hooks onto a large hole in the throttle plate.
A problem that does occur is the plate becomes bent when the mower us pushed under shrubs. This drops the speed of the mower to a low idle. If this is the case then with a pair of pliers, gently twist that metal plate to obtain a RPM setting of 3,100. Don't be tempted to increase the revs to much or the conrod will break and punch a hole through the engine block.
May 07, 2014 | Craftsman Garden
How do i fix the pull start and re tension it so cord retracts?
You take the top of the motor off with the starter, then rewind the spring,then is a good idea to replace the rope with a new one they sell rope at a lawnmower store, get 5 feet or more if the rope is up on the handle, take a piece of rope with you to get the correct size.
Aug 20, 2012 | Electric Earthwise Corded Lawn Mower...
Engine when started, runs over RPMs that it's designed for
The spring acts as an engine govenor, i would say the spring is not connected properly, if you have too much tention on the spring you will increase the revs.
Mar 18, 2012 | Garden
Need exploded view of carb n governor linkage n spring location
the govenor spring fits in with the throttle linkage and the other end goes in the govenor...good luck
Nov 07, 2009 | Garden
Choke spring carburator assembly
how do you assemble the two springs on a sprint 375 briggs and stratton ?
Aug 14, 2009 | Craftsman Garden
The engine on my Sprint 375 floods when trying to start
Check the float in the carb. bowl for gumming and clean your carb.. If you haven't done so already. Or you can try running a fuel treatment through your fuel. That may help you with your flooding issues. Good luck.
May 04, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
627 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
