Question about Linksys Wireless-G WRT54G Router
My wireless name (SSID) and security settings keep changing on their own!
I have installed my wireless router, set security settings, entered the encryption key, and then I'm able to wirelessly connect to the internet (via laptop) for approximately 1-3 days. Then, the wireless internet access is lost. When I go into the Easy Link Advisor and check my settings, the SSID has changed, the security settings are gone, and the encryption key shows a new set of numbers/letters. Why is the SSID changing on its own? To troubleshoot this, I have entered my IP address in the web browser and changed my SSID back to the correct name; however, nothing seems to fix the problem.
  • mdr27 Oct 23, 2008
    I had a password to the router, but it was the "admin" default one. I have now reset to a strong password and will see if this works. Sometimes the easiest answer is the right one.
    Thank you.
  • Carl Navarro
    Carl Navarro May 11, 2010
    I know there was a reason why I'm a Netgear house. Are you setting a password to get into the router? A strong password?
    Maybe someone is fooling with it.
Thank you for the helpful advice. My previous router (same model) was struck by lightening, and I replaced it with this one. However, I never had this problem with the prior router. I have called Linksys tech support number several times and was disconnected and then left on hold for a ridiculous amount of time. I like the idea of asking for a replacement since I have my receipt and original box. Thanks again!
Posted on Oct 23, 2008
  • 59 Answers
well i saw the problem u r facing
and the only soution for it is the upgradation of the firmware ....
i was facing the same one on my router and it got corrected ....
otherwise u can call the customer care no of the the routers company and they will give u the replacement
I want to set up a secure netgear wireless connection
THIS IS A SUPER QUICK AND EASY FIX!
Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  3. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  4. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  5. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  6. Click Apply to save the settings
Dec 11, 2010 | NetGear WGR614 Wireless Router
How do I lock my Dell TruMobile 2300 wireless router to keep the neighbors from getting access to my wireless internet connection
press win key + r
under run type cmd
on the command prompt type ipconfig
not down your defaut gateway.
type it in your web browser, and then enter the correct user name and password for the router.(i u dont know the user name leave it blank or try admin for both user name and password or its combination o call dell for it)
Create a unique password on your router : Once you have logged into your router, the first thing you should do to secure your network is to change the default password* of the router to something more secure.
This will prevent others from accessing the router and you can easily maintain the security settings that you want. You can change the password from the Administration settings on your router’s settings page. The default values are generally admin / password.
Change your Network’s SSID name:
The SSID (or Wireless Network Name) of your Wireless Router is usually pre-defined as "default" or is set as the brand name of the router (e.g., linksys). Although this will not make your network inherently* more secure, changing the SSID name of your network is a good idea as it will make it more obvious for others to know which network they are connecting to.
This setting is usually under the basic wireless settings in your router’s settings page. Once this is set, you will always be sure that you are connecting to the correct Wireless network even if there are multiple wireless networks in your area. Don’t use your name, home address or other personal information in the SSID name.
This is sufficient to secure your router from other to use it.
Aug 11, 2010 | Dell TrueMobile 2300 Wireless Router...
How do I secure my Dynamode BR 6004 WG1 Iam a
To secure your wireless network from unauthorized access, you need to at least configure the wireless router with encryption, and the SSID, and change the router's default login password.
Please follow these instructions :-
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA). The encryption key can be easily set up using a passphrase (it can be an alpha numeric phrase or words).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Jul 23, 2010 | Dynamode (R-ADSL-C4-W) Wireless Router
I need to install a password to my router and I do not know how
(http://192.168.1.1)
3. Enter the router setup, login and password (the default login = admin
and default PW = admin)
4. Go to set/change password and Change the admin password
If you have any problems let me know.
Nov 14, 2009 | Linksys Wireless-G Broadband Router
I do not have the software installation
plz download it from the manufacture website
Nov 12, 2009 | Linksys Wireless-G WRT54GS Router...
Change SSID
There are other things you should do to secure your wireless router besides changing the SSID. Follow these steps to secure your wireless router : -
3. Enter the router setup login and password
6. Setup encryption key the strongest is WAP2
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 02, 2009 | 2wire (1000-400108-001) Router
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
My wireless network gets dropped
HI! that is correct.. your device wont connect bcoz you change the wep, ssid name etc on the router.. if the security settings is change from the router and your wireless devices have the old settings it wont work and it will not connect.. you need to enter the new wep, ssid name etc to the wireless devices in order to connect to the wireless network..
Jul 10, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I need to secure my router. I had payed to have it set up when I was getting my computer fixed only to find out that my son could log on with out a password. How can I fix this.
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
************DETAILS************
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key .
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
Apr 08, 2009 | SMC Barricade 7004VWBR Wireless Router
I WANT OT PUT PASWORD TO MY WIRELESS BROADBAND ROUTER SO ONE CAN ONLY OPEN OUR COMPUTER AND SELECTED PEOPLE CAN ONLY USE THE WIRELESS CONNECTION.HOW CAN THIS BE?
Log into your router by opening your web browser software, for example Internet Explorer. Type in the address field the ip address of your router. The ip address depends on the manufacturer, but it should look something like this - 192.168.1.1 . A window should appear asking you for your user name and password. If the router is set to default settings, the user name should be ADMIN and the password should be ADMIN. Hit enter. This should bring you to your routers configuration window. lynksisssid_thumb.jpgSSID screen.Go to your wireless tab / basic wireless settings. Enter a SSID (wireless network name). The SSID may be on a sticker on the router or you could make one up. Choose a wireless channel. Disable your SSID wireless broadcast. Save or apply changes.
linksyswep_thumb.jpgWEP / WPA screen.Go to your wireless tab / wireless security. Choose enable. Choose either WEP or WPA encryption, the latter is a more secure choice. Choose 64 or 128 bit encryption, again the latter is a more secure choice. Enter a passphrase and write it down so you can enter it when it is called for when installing the wireless software on your wireless computer. A hexadecimal WEP/WPA key should be generated. Save or apply changes.cheers
Dec 03, 2008 | Edimax 4 Port Wireless AP Broadband Router...
Linksys Wireless-G WRT54G Router Logo
1,021 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
