Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Disconnect water lines to ice and water maker in samsung side by side
Removing freezer door
  • sanford schulte Feb 09, 2012
    when I remove bottom cover an orange and white water line have an inline fitting that connect the lines how do you disconnect line from the connector.
TJBENGR
  • 121 Answers
SOURCE: Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Posted on Apr 21, 2008
SOURCE: Samsung RS2555SL Ice Maker gone nutty!
Forget how to set ice maker? can you tell me how to do it. Please
Posted on Apr 25, 2008
  • 145 Answers
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Posted on Jun 07, 2009
  • 212 Answers
SOURCE: Samsung RS26 frozen water line in Ice maker
all you can really do is put heat to it (hair dryer) but be careful that you don't melt the water tube. or you can remove food and leave door open til it melts
Posted on Jun 24, 2009
daddyo742001
  • 70 Answers
SOURCE: ice maker won't work
Temp needs to be down to 0 or below for ice maker to activate. once that happend arms that push ice out will go around and made switch in end of ice maker that turns on water selenoid valve that adds water. this could also be electronic switch. main thing is its cold enough to activate. If it don't work then Ice maker may be bad or no power getting to it. turn freezer as cold as you can may mean setting refrig side warmer. If it has coil under refrig clean it out. Air around frig should be 68 - 75 degrees if poss.
Posted on Jun 29, 2009
Water on door wont dispense
Your water line could be frozen inside the freezer door. Open your freezer door and remove the kick plate on the bottom of the unit. Follow the water line from the door under the unit and it will be clipped under the unit. Pull out the water line and disconnect either line from the coupler (push the water line in and hold the ring then pull out the line). After you do that close the door and try the water again, if you get water then you will need a low wattage heater for the door.
Mar 14, 2013 | GE PSS25MGN Side by Side Refrigerator
Ice maker water not coming out of the outside , no water supply to the ice maker
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
Jun 22, 2011 | Samsung RS2630SH Side by Side Refrigerator
We have an Electrolux S/S side by side w/Ice&water though the freezer door. The water flow through the door has been inoperative for several months but the ice maker continued to work fine. Water...
check and see if there is a built in filter pack inside the back of the fridge or it could possibly be that one of the lines has froze internally and or the open close valve at the water inlet inside has worn out
Jan 18, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water dispenser stopped dispensing water but ice maker is still working fine
I had the same problem. Ice maker works fine. Removed the kick plate at the bottom of the fridge to expose the water line. I disconnected it and then pressed the dispense button. Water pumped out of the line so i know water was getting all the way to the freezer door. I went overkill but it worked. I removed the freezer door and placed it outside. (disconnected the power to the door by disconnecting the plug at the top. and then removed two screws/bolts at the top and the door lifts up and off) I set the door on a patio table with the bottom facing up. I picked up some 16 gauge wire ($6 at Home Depot) and ran it up the water tube from the bottom of the door. The bottom is more of a straight shot up the water line. I also took a turkey syringe used to inject juice into a turkey and i shot very hot water up the line with the door upside down. This allowed water to run up the line and unfreeze it if it was frozen. I let it sit outside for 30 minutes and put the door back on and now it works like a champ. The line was either frozen or it was obstructed. The water line is surprisingly small. Took less than an hour and I now have water again. Not tough at all...
Oct 06, 2010 | Whirlpool GS6SHEXNL Side by Side...
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
I have a Hotpoint HSS25GFTA WW Fridge that has side by side doors with ice/water dispenser in the freezer (L) door. I still get ice fine but my water dispenser has 'died'. The water has always come out tap...
Hello:
It is very common to have the line in the freezer door freeze up. I would start there first. If that's not it then next step would be your water valve which is located in the back/bottom of the fridge. It is a dual valve( one side for ice maker the other for water dispenser). you can check that by taking off the front kick plate and on the bottom freezer door hinge you will see the line entering the door. Follow it towards the under the fridge and you will find a coupling. Disconnect it and see if there is any water coming out when you press actuator on the door .. If yes then its frozen if no your valve is Kaput.
Cheers
Jun 10, 2017 | Hotpoint HSS25GFP Side by Side...
Removing the doors from samsung refrigerater RFG297AA
I'm in the same boat. I'm sitting here withe freezer door unscrewed and I have no idea how to disconnect the water line going up the side of the freezer door. I guess I'm going to rip it. I was going to give this hunk of **** to goodwill since the freezer still somewhat worked but now this, screw it.
David
Feb 20, 2010 | Samsung 24.8 Cu. Ft. Side-by-Side...
Ice maker not working
then you either after doing this have a water to the ice maker problem, or an ice maker issue
go to the water valve and disconnect the small plastic line at the water valve and with a cheater cord connect it to the water valve, naturaly remove the factory connector at the water valve first and plug your cheater cord into the ac if you get water out of the valve the valve is good if you do not the valve is bad
if you get water out of the valve then you have a problem in the ice maker IF the line to the ice maker is clear and no obstructions
Apr 12, 2008 | KitchenAid KSBP25FKSS Side by Side...
Ice maker won't fill
leaky solenoid? could cause ice build up
Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
218 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
