I can not delete a download called,freeride games player. It keeps saying the program is running, that I should close the program, then return to control panel to delete. I have deleted all referance to the program except for in add and remove. Please help, my computer is acting up and it must be this download causing the problems. Thank you, Ginny
  • ginnylee631 Oct 25, 2008
    Thank you so much. I found the solution on the free games web page, although I believe your solution would have worked.
    Thanks again,
    Ginnylee 631
  • 749 Answers
Start the computer in safe mode by pressing f8 as the first screen appears and selecting safe mode.
it will start slower than normal , and when it does , uninstall , not delete the program in question. if you just delete the directory, it will leave junk installed you dont want. Sooo unistall it from it's own uninstall program or from the "add & remove programs" section in the controll panel.
Posted on Oct 23, 2008
Why I cannot download games any more on freeride games
Sometime websites get in legal problems because they provide links to download copyrighted material
Problem might be the ISP, the SERVER or local authorities.
So they change politics.
Apr 26, 2015 | Video Game Consoles & Games
Ran malwarebytes and now freeride player won't work
anti-virus/malware programs sometimes recognize as malware that are not. They are not perfect. You should check to see what actions to carry out before you quarantine/delete all, because it may have detected your favourite program !!
Most such programs back up the registry before running. Check this and reinstate it if possible. If this does not work, perform a system restore on your computer to its last working state (the last restore point created usually) (NOT a system recovery !). This should not harm any of you data.
Or, you may choose to uninstall any remnants of the program in (free ride player), and install it from scratch again.
Jul 27, 2014 | Free Ride Games Video Game Consoles &...
I downloaded " The Stupid Test" APP Game from Appslib , I played several parts of the game, then I went to log off and a pop up came onmy screen saying " Check into Stupid Test" with a skip or install...
To close the pop up try clicking CTRL-ALT-DELETE go to TASK MANAGER then go to PROCESSES, find the process for the Stupid Test App,(if you cannot find it look in APPLICATIONS, end the task, this should at least close it temporarily. Next go to your start menu, CONTROL PANNEL --> Uninstall a program search for the name of the program here, click to uninstall it. After you have done this, go online and download a program called Malware Bytes, install it and do a Scan, this should pick up the rest of the program left behind, after you have scanned delete anything it finds. This should fix the problem.
Nov 23, 2013 | Archos ARNOVA 10 Android Tablet
How do i reinstall extension player after seeing exetender fatal error please.
often seen after un-installing the FreeRide Games player....
try ccleaner or comodo registry cleaner to clear-out these left-overs from bad un-install programs.
Sep 12, 2012 | Computers & Internet
It sounds like you have a virus attached into your installation from freeride.
This wouldn't be the first virus that came from there, and I'm sure it won't be the last.
I would do this:
First, disconnect from the internet.
Second, run a COMPLETE system scan, including system and hidden files, and including any removable drives that are attached.
After that, click start, then run
Type in MRT, and press enter, this should start the Malicious Software Removal Tool.
Have it do a full scan of your system as well.
Now, after that, close any open programs, and reboot.
Re-enable your network connection, and try going to the internet.
See if that got rid of the pop up box.
If all is well, then you are good to go.
If not, then you need to somehow download CCleaner, from
It is an excellent program for getting rid of junk on the drives of your computer.
Get it, install, and run the cleaner.
Click analyze, the program will do it's thing, and tell you how much junk it is getting ready to remove.
Then click clean, and all the junk goes away!
Next, click on the registry part of CCleaner, it's on the left hand side of the program box.
Have it analyze, then after it's done, I would click save changes, this makes a system restore point, that way you can put your computer back the way it was in case something should go awry.
then click fix problems, and it will fix your registry errors.
After it's done, close the program and reboot.
See if that fixes the problem. 99 % of the time, it will make your computer run as good, if not quite a bit better than it was before you installed the freeride stuff.
Ihope this helps you out, and good luck!
Mar 15, 2011 | Acer Computers & Internet
HI, I am am having problems with my Philips GoGear Flash audio player SA2625. When ever I turn it ON, all it says is "Philips" then it turns off. When ever I plug it in it says "OK to disconnect", the...
I found a restore fix by pressing the return button while plugging into a PC with philips device manager open - the MP3 player then was restored to factory defaults :-)
Jun 16, 2010 | Philips GoGear SA2625/37 MP3 Player
Cant get this gaming program i downloaded off internet explorer
use a antivirus scanner and reset ie to defaults. normaly is a spyware infection.
Feb 09, 2010 | HP Pavilion dv6000t Notebook
I canot get Free Ride Games off of my computer.
Try going to your computers search bar in the start menu and put in the name of the game. Many selections will come up. Delete them one by one until they are gone. I'm assuming you've already been to the "Add and remove programs" section. You may also want to run CC Cleaner(free download) AFTER you do the preceding, This will remove any registry entries left by the game. Thank you, Dana
Jan 17, 2010 | Computers & Internet
Cannot recieve text messages and read messages keeps deleting
i just went through this problem today... go to options and the scroll down to status.. if it says 0 bytes then you need to clear all old texts, after you do that make sure all programs are closed. You do this by holding down the ALT button and the return button.. make sure you close every last one of the programs.. take your battery out, then you should be go to go!
Mar 10, 2009 | AT&T Blackberry Curve 8300 Smartphone
Problems with a disc that keeps reading unformatted
This has happened because somehow the program didn't "Close the Session" and make it so data could be added, instead it has "Locked" the disk to prevent any more data being overwritten and ostensibly corrupting the disk.. In this case however it has also locked out everything... and returned it to the "Unformatted" state. Although I suspect you will NOT actually be able to record anything to this disk in actual fact. You MAY be abale to use a program called Unstopable Copier, if ya lucky :Download HERE
Aug 08, 2007 | Panasonic DMRES15 DVD Recorder
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
