Question about Numark Industries Numark NDX200 Tabletop CD Player
Why is my numark ndx 200 cd player if freezing up?
Numark cdn450 has tray error message in left well
For all kind of brands cd or dvd players There is in every cd or dvd tray in the front bottom or under the tray so crazy you can not think an microswitch necessary that will be by mechanic close of the tray detect if the tray is closed and give a timed signal (close or open) to focus laser for reading of table of contents if the belt is bad it can take to long by a slipping tray drivebelt for the detection , or the microswitch or brass plate contacts are have a little corrosion on it or even it can be broken by a missing timing.
Dec 23, 2013 | Numark Industries Numark CDN450 Rack Mount...
Can i connect a numark NDX400 to my sony surround sound its a s master amp?
Yes, you should use CD inputs and should work like a champ, hope it helps..
Oct 16, 2013 | Numark Industries Numark NDX400 Tabletop...
One cd player wont read
Take a can of compressed air and blow into the player all around and try it. The heads get dirty over time and stop reading. Clean the dust off the laser head and they usually start working again.
Feb 28, 2013 | Numark Industries Numark CDN 22 Mk4 Double...
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
Feb 28, 2013 | Numark CDn25 Professional DJ CD Player
I cant hear music from the headphones numark cdj 200
Since there are no headphone outputs on this unit, I'm not sure what the trouble is. Please be more specific. Thanks.
Jan 12, 2013 | Numark Industries Numark NDX200 Tabletop...
How to connect a numark cdn25+g
This should help:
http://www.numark.com/images/product_downloads/cdn25_quickstartguide.pdf
You do need an amp.and a mixer. You mixer should have microphone jacks, and a pream or switch to allow you to use lowZ, High Z or amplified microphones.
Mar 29, 2012 | Numark CDn25 Professional DJ CD Player
Need to find how to open a NXD200 from numark... cause i got a problem with 1 button
It's just the screws in the bottom that hold the top and bottom shells together Possibly some on the sides.
Sep 21, 2011 | Numark Industries Numark NDX200 Tabletop...
A cd is stuck inside my numark nd400 tabletop scratch cd player
Only safe way is to take covers off to get to the player. A common problem is jamming by a label that came off OR the little belt that drives the carriage has deteriorated or failed. Only way in either case is to open the unit.
Jul 11, 2011 | Numark Industries Numark NDX400 Tabletop...
Numark Industries Numark NDX200 Tabletop CD Player Logo
70 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
