Question about PNY XLR8 NVIDIA GeForce 8800 GT 512MB GDDR3 PCI Express Graphics Card
Problem updating drivers
I'm working on a custom built NLE Workstation with an XLR8 card onboard (WinXP Pro SP3.) The card has been working since we built it a few months ago. However, when another tech inadvertantly tried to update the drivers, the display went dead after the display wizard uninstalled the drivers. Upon reboot when the wizard was supposed to automatically reinstall them, we get a warning beep from the motherboard (EVGA nforce 780i SLI) and no 'automatic reinstall.' We then rebooted in Safe Mode the display came up just fine but, it freezes the USB mouse and keyboard so we can't interface with the system. I even dragged out an oldschool p2 mouse and keyboard and it did the same thing. We couldn't figure out any way around it the last time this happened, the only solution was to wipe the drive and start again. Unfortunately, doing so corrupted 4 out of the 5 drives used in the workstation and had to be replaced. I do not want to go through that again! Any ideas? Suggestions? HELP!
5 Suggested Answers
bhiga
  • 119 Answers
SOURCE: Installed new graphics card and Windows won't start
If your new video card has a power connector, make sure it is connected to a power plug. If you already did that, it's possible your PC's power supply doesn't have enough power to run all your connected equipment.
To get your old card running, hit F8 repeatedly during boot-up until you get the boot options. Select VGA mode. It should boot up properly then.
Once booted into VGA mode, set your screen resolution to something simple like 1024x768 or 800x600, then reboot.
If that doesn't work, try hitting F5 repeatedly during boot-up to boot into Safe mode. You can then adjust your settings again there.
Posted on Apr 07, 2008
  • 24 Answers
SOURCE: Gateway FX7026 w/ 8800GT 512MB Video Card / Vista 64 Premium OS
It is a known issue. It is not a fault with the card, but a power saving method used by Nvidia. If the card is not being stressed, or even if it is, it will clock down to it's 2d speeds. This is fine if you are just surfing the web or other light tasks, but can cause chaos if you are gaming or folding at home.
You can force your card to run at it's maximum clocks in 3d mode by using a program called Riva Tuner. There are several good posts on the net on how to use this fix, but I can't seem to link to them as this site will not allow me??
I am using it myself, as I had the same issue with my 2 GTX 260's.
Posted on Dec 25, 2008
pingsam
  • 23 Answers
SOURCE: GeForce FX5200 will not ''soft reset''
please go to the following site and download the driver detective software: http://www.drivershq.com/Drivers/VistaDevices/NVIDIA-GeForce-GPU-SLI-Driver/26280/Drivers.aspx
please rate my answer.
Posted on Dec 31, 2008
Slasher_X
  • 767 Answers
SOURCE: I have a PNY Quadro
Reseating the card is a good idea. Also make sure it isn't getting too hot. I suggest updating your Nvidia Drivers here.
Posted on Jun 20, 2011
HP dc5000 compaq - running win xp pro sp2 and it won't upgrade to sp3. Sp3 needed to run Nero 11.
go to this link http://www.microsoft.com/en-us/download/details.aspx?id=24 download winxp sp3 exe follow instructions disregard for IT professionals and developers this is the download you need after installing goto windows update and download and install updates
Aug 24, 2012 | HP Computers & Internet
Asus 1.2ghz 1.0 gb ram I added a usb2.0 card as
Check for new drivers from the USB card's manufacturer's website...if that doesn't work, try removing and reinstalling the card.
Dec 14, 2009 | Computers & Internet
Nvidia 6200 gap graphics card not recognized under WIN XP
DId you hook up the secondaary power supply on the side a 5 pin 1/2 inch in width?
Nov 20, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
Winxp pro sp3 not full version
It cannot be "fixed" -- this is the correct version, after applying the latest updates.
Nov 05, 2009 | Microsoft Computers & Internet
I have a aark24 installed on my computer windows xp operating system and cubase sx3 The Aark 24 is not working My latest driver update is 7.13. is there maybe a update driver software available?
Aardvark is only stable with xp sp1. 7.13 and 7.14 are the last drivers ever made. They were made prior to SP2
You will have to pull the pci card, delete all the aardvark drivers and reinstall windows. Then go to windows update and install everything up to SP2. The stop and turn off auto updates. Dont surf after that. Unplug any internet connections.
Oct 23, 2009 | Aardvark Direct Pro Q10 (bundle) External...
"NO SOUND CARD" IN WINXP SP3
Go here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=472259&prodTypeId=12454&prodSeriesId=472277&swLang=13&taskId=135&swEnvOID=1098
Dload and install the sound drivers or any other drivers you may need as well.
you should be good to go
Thanks for posting and please rate.
Mar 17, 2009 | Intel Motherboard
PCMICA/USB 2.0 not recognising usb devices
if it works on the onboard usb.
Theres a chance that either the pcmcia slot drivers are incorrect, or the actual slot is faulty.
Try it in another slot, if you have 1.
update any onboard device drivers. if applicable. try the card in a different laptop. to eliminate the card. alternatively, try a different card in the slot. wifi card et,c.
Mike @ compurepair.
Dec 16, 2008 | Compaq Armada M700 Notebook
Driver not working with recent OS versions
I dont get it. On win98 the driver works, on xp or later it doesnt? the windows doesnt find the driver that you've downloaded?
Feb 05, 2007 | S3 Trio64+ Graphic Card
PNY XLR8 NVIDIA GeForce 8800 GT 512MB GDDR3 PCI Express Graphics Card Logo
Top PNY Computers & Internet Experts
David
David
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
