Question about Frigidaire Washing Machines
What causes an e20 error on an affinity LTF6000ES1 washer
Affinity LTF6000ES1 washer has standing water and will not spin or drain. E20 error flashed
ghappliances
  • 126 Answers
SOURCE: washer won't drain completely. gives
YOU NEED TO CHECK FOR A BLOCKAGE IN THE PUMP OR THE PIPES LEADING TO THE PUMPS.ALSO CHECK IF THE PUMP PROPELLER IS SPINNING CORRECTLY AND IT HAS NOT BEEN DAMAGED.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
onthejob5130
  • 640 Answers
SOURCE: Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Posted on Jan 31, 2009
SOURCE: ltf6000es1 frigidaire affinity won't spin belt
How do you test the door lock Switch?
Posted on Apr 27, 2010
  • 1382 Answers
SOURCE: my washer stopped and i
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you !!
Posted on Aug 19, 2010
  • 3 Answers
SOURCE: how do I take my Affinity washer apart to fix an E20 clog problem
E20 = Clogged drain pump.
Tools I used: vice grips, both phillips and standard screw drivers, flash light and an 8mm socket with ratchet.
I solved this problem by removing the rear oval type cover by removing the 6 phillips screws that hold it on, but first thing is to unplug the machine! I unplugged the electrical connection going to the pump. Then I removed the hose closest to me by removing the pinch clamp with a pair of vice grips. Then I removed the two screws holding the pump down to the frame of the washer (8mm socket). Then I removed the farthest hose by removing the pinch clamp with the vice grips. Once this was done I took out the pump. The hose entering the pump contained a sock, debit card and thirty-five cents!
Once I removed all of the debris I reversed the order but this time I used an automotive hose clamp which makes re-assemble waaay easier!!! (Saves about 30 mins) Total repair time took me 1 hour, but if you use an aftermarket hose clamp instead of the pinch clamp on the hose coming into the pump this will save you at least 30 minutes because it is soo difficult to put back on because of the tight space.
One-hour, a minor cut and $2.35 for the clamps later all is fixed!
Posted on Sep 12, 2010
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Error code 20 on an affinity frigidaire
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 23, 2012 | Frigidaire Affinity ATF6000F Front Load...
Spin cycle goes very slow or doesn't work.
Hello, After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Thanks
May 19, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
My kenmore he washer will not drain all the water also have code E20 flashing
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
Dec 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
My washer will not spin and posts E20 error
E20 means that there is a clog somewhere in the drain line. Check the hose, check the check valve at the pump, make sure nothing is clogged or stuck. It should not take you that long to find the problem.
Aug 23, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
