Panasonic blu-ray player shows F61, shuts off, won't turn on
My 1-year-old Panasonic SA-BT230 blu-ray player/home theater system is now unable to turn on. Every time I try to turn it on, it displays "F61" and shuts itself off immediately. It was doing this sporadically for about a week, but over the last two nights it has done this constantly. Please help!
Benimur
  • 6966 Answers
SOURCE: panasonic home cinema model sa-ht75
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 26, 2008
xCAUSALITYx
  • 210 Answers
SOURCE: Sharp BDHP20S Full HD Aquos
Prob the mainboard, like a needle in a haystack trying to track a fault down on that board - Better to replace it.
Cheers
Posted on Jun 02, 2008
  • 151 Answers
SOURCE: I have a panasonic sa-ht855
Your sound/power stage is not working. Set needs to be taken in for repairs.
Posted on May 12, 2009
SOURCE: panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
Posted on Aug 26, 2009
SOURCE: Salt blu ray will not
Update your FW to at least 100112.01.XSS
Posted on Jan 10, 2011
Panasonic SA-BT337 doesn't play UK Blu ray discs
it's not region free. I had to get mine unlocked just to play multi-regional DVDs and still unable to play my collection of multi-region blu-rays. still looking for answer myself on that one.
May 25, 2011 | Panasonic Audio Players & Recorders
How to unlock dvd from all region in panasonic blu ray player Sa BT230
I believe this model is already Region Free out fo the box. What does it show on the back?
Apr 21, 2011 | Panasonic Home Theater System System
On my Panasonic SA-BT230 blu ray player it will not recognise my external hard drive in the USB port, how do i fix this? thanks
hi i have a 500gb external hard drive with its own power supply, also same blu ray player, to get it to recognise your usb device you need a tool like mini tool partition wizard i got mine from a torrent site but im sure it has a free trial, any way connect your HDD to a computer and back up all data before continuing, then open the partitioning tool (these options are not available in windows which is why you need third party software) select the HDD and select delete (only after you have backed up your data), then apply once this is complete you will see the HDD is is now "unallocated" select the drive again and select create on this box select fat32 file system and change from logical drive to primary and give it a name if you like then hit ok then apply and thats it. move all your data back and it will see the drive again.
I should mention that i hit one snag when i did this, as you know the bluray player will play movie files .AVI and not .MKV or .MP4 but once i carried out this operation my blu ray player (sa-bt230) will play these other formats but not the .AVI ones, which in the manual is states it will not play the others only .AVI's.
not a problem as such for me as i can now watch my downloads in better res and with DTS sound.
hope this helps
Feb 17, 2011 | Panasonic Home Theater System System
Is panasonic sa-bt230 vs sc-bt230 the same?
sc-bt230 is the name of the whole system, sa-bt230 is the name of the main unit only
Sep 29, 2010 | Panasonic SCBT230 Theater System
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
SA DT310 showing F61 and closing down
the F-61 code means your audio outputs are bad you must have it repaired
Dec 19, 2009 | Panasonic Home Theater System System
F61 error
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
Feb 22, 2009 | Panasonic Home Theater System System
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic home cinema model sa-ht75 . shows f61 disconnet output ic ,still shows f61
1. fan not turning;
2. cold solder;
Apr 26, 2008 | Televison & Video
Televison & Video Logo
512 people viewed this question
Top Televison & Video Experts
