Question about Sanyo DP42746 42 in. Plasma Television
Sonyo tv 26' B6470210715099 tv
When tv is turned on there is no picture not even when the cable is connected. Sounds as if the when off the air.Try channel search but will but comes up zerohannel foound. remote will only go to 2 subject in the menu Whats' the problem.
  • 905 Answers
The tuner probably needs better solder put on which the repair shops get to fix known tuner problems
when the tv heats up the solder cracks and don't make good contact , thus needing the solder that withstands the heat better
hope this helps
electech
Posted on Oct 23, 2008
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Jul 04, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Power is on tv picture not showing
Thank you for bringing this up with us. I understand that your TV is powering on, however there's no picture on it.
The common issue why you have a blank screen knowing the fact that your TV is on, is just that the cable might not properly or thoroughly connected, please check your cable if they connected properly if they are, please try to tighten the cables.
Please let me know whether it works.
Thanks.
May 14, 2011 | Vizio M261VP 26" LCD TV
VHS pictures shake
Did you try adjusting the tracking control on machine?
Sep 21, 2017 | Insignia LCDTV26 26 in. Television
I purchased my Dynex 26(?) late june, and fine until yesterday. watching tv, which is connected to a time warner cable box. tv hums both cable and tv switch off. turn both back on, but now tv screen is...
Bad power supply,Hard to find,They went out of business. may try to find a remanufact,or used from Shop jimmy,or even Ebay. Encompass does not have them. This is why I recomend Extended warenty. I handel all of central FL.Best buy was giving a trade in for another brand TV. If you get rude enough,They might let you return it. Trust me is works often.
Oct 26, 2009 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
No sound and picture not full screen when connected to pc
if you have your tv connected to your pc with a vga cable, you will not get sound, since the vga does not carry sounds, only pictures. to change the settings on your pc to make full you will have to change your resolution size on your pc in your control panel
Apr 05, 2009 | RCA L26W11 26 in. HD-Ready LCD Television
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
Philips 26
There is an input imbalance. Either try connecting your cables to different inputs on your TV, or try connecting to different outputs on your DVD player. (Only worry about the yellow video cable bit initially). Alternatively, try a different cable type; you'll have some ins and outs that don't use RCA connectors.
Mar 03, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Sanyo DP42746 42 in. Plasma Television Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
