Question about True TSSU-48-12 Refrigerator Commercial
Side of evap coil freezing up on true tssu4812
Trane Heat Pump model TWV036B140A1 (inside unit). The coils on the blower have started to freeze up lately which means that they have to be thawed out to allow air to pass through to the duct system.
You either have an air flow problem or your low on charge. Check filter and check to see if evap coil is dirty by taking off the metal door on the evap coil it has 5/16 screws in it is by the coil on the coil. Look inside the coil to see if its dirty you can take a flash light and shine in on one side of the coil and look at the other side to see if you can see the light if you can air is passing thru. low on charge you will have to have gauges to check this.
Sep 18, 2014 | Heating & Cooling
True 60-16 not cooling
yes,one problem of undercharged
Feb 05, 2014 | Refrigerators
Low pressure on suction side and no cooling
If your running 134 a your short of gas
if your running 404a your short of gas
check the super heat it should be 5 ktd
Jan 10, 2014 | True TMC-58-DS Commercial Refrigerator
Clicking sound warm air
Looks like your compressor is bad
Jan 15, 2013 | TRUE TSSU4812 Commercial Refrigerator
Evap coil freezes at top next to defrost thermostat
You will need to replace the defrost thermostat located on the coils. Here is the part to order.
Dec 03, 2012 | Amana DRS2663B Side by Side Refrigerator
Delay on evap. fan sistm.404a
Give the evaporator a chance to get cold, then check you've got power to the fan, via the evaporator thermistor and door switch
May 02, 2012 | True Freezers
MAYTAG MSD2734GE side-by-side fridge/freezer. The freezer coils on a regular basis (3-6 weeks intervals) will freeze. We will have to remove the coil covers and manually defrost them before it will...
I have written tips pertaining to each of those 2 issues
Drian blocked tip...http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
Evap. coil freezing up tip...http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
i have 2 pictures in the coil freezing up tip and they always for some reason post incorrectly so here they are..oldtech2332_43.jpgoldtech2332_44.jpg
Aug 22, 2011 | Maytag MSD2734GE Side by Side Refrigerator
We have a true T49F freezer and the evaporator fans are not running. The compressor is running on startup. The coils are cold. But are freezing up. Shouldn't the fan be on, or does the cabinet have to...
Freezers have a sensor that is referred to as a "Fan Delay/Defrost Terminator". It senses the temp during the defrost cycle. Usually, when the evap temp reaches about 50 degrees, there should not be any frost or ice on it. This device terminates the defrost cycle. It also keeps the fans off so warm air is not circulated. When the evap gets to about 20 degress or so, the sensor switches on the evap fans. If the fans are not coming on, either the sensor is bad or the evap is not reaching the proper temp to cause the sensor to turn on the fans.
Hope is helps to clear up some things and point you in a direction as to what might be going on.
Jul 12, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
True TSSU-48-12 Refrigerator Commercial Logo
95 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
