Question about Toro Garden
Toro 5100-d reelmaster motor dies when cutting,motor don,t speed up
3 cyl. diesel motor seems like governor is not working,if it has one
3 Suggested Answers
  • 60 Answers
SOURCE: My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Posted on Jun 24, 2009
rycgl
  • 1545 Answers
SOURCE: toro recycler rear bagger linkage set-up to
Hopefully, this will clarify it..
http://small-engines.com/bsgovernors.html
Posted on Sep 15, 2010
What hydraulic fluid do I use in my toro 4500d reelmaster
Toro premium all-season hydraulic fluid OR see manual page 25.
Jan 15, 2018 | Toro Garden
How to replace throttle spring on toro 16585
Your governor spring goes from the governor arm to the throttle shaft on the carb. hope this helps. Let me know if you need more help
Aug 09, 2014 | Toro Power Lawn Mower
Can i stretch the spring to adjust the governor
No that will not adjust your speed the governor is there to protect from overspeed and give more power when required like heavy grass cutting,it is operated by air generated by the cooling fins or internally...so don't mess with the spring.. Good luck
Jun 28, 2014 | Toro Power Lawn Mower
1981 John Deere 1050 Diesel Tractor - Engine will go to high idle by itself. You can shut key off and engine will eventually die. What would cause the engine to high idle? Afraid engine will lock up.
There are 2 types of governors on diesels. one is controlled from the foot and is fixed speed at the foot setting. The other is variable speed which will run to high idle if the setting is not changed IE on start it will idle ok but if you use a fast setting on a hand throttle say to warm up the motor it will run to high idle. I suggest that if you have not had a problem before then you should have a diesel pump specialist look at it as there may be a fault in the governor control.
Jun 23, 2013 | John Deere Tractor Side Screen...
Toro briggs OHV runs too fast
throttle spring could be broken stretched or missing
Nov 14, 2012 | Toro Lawn Mower With Toro Power Tools
I have a self propelled Toro walk behind that does not have a throttle control. Stalls out if grass is just a bit high. How/ where do I adjust throttle
Most new mowers do not have a throttle adjustment, the motor has a govnor that helps the motor speed up when the load requires it. The first thing you should check is that the blade is sharp which makes it easier to cut the grass. If the grass is still too high for the motor to keep up, it's usually easier to raise the deck (lower the wheels) so you are not cutting as much grass on each pass. Then lower the deck to where you want the grass height to be and make a second pass.
Jun 06, 2011 | Toro Power Lawn Mower
Hi, I have an older toro snowblower w/ tecumseh 7 hp. When idling it is fine,but with full throttle the engine seems to over rev. I've adjusted the 2 carb settings to specs and it seemed to run well, but...
The carburetor settings should be to make the engine run correctly, not meet some specification. The upper jet is for idle adjustment and the lower adjustment is for high speed running. It the lower jet is too far CW, the engine will be running lean and tend to miss. Too far CCW and the engine will run 'muddy' and tend to blow black smoke from the exhaust. Throttle speed is determined by a balancing act between two springs, the governor, and the throttle position. Generally, there are several options for spring placement--a series of holes drilled in the throttle arm and the governor arm set this balance. Have the springs been replaced? Have you tried a fresh spark plug? You may require professional assistance on the throttle adjustment. Hope this helps!
Jan 27, 2011 | Garden
Were can i get hold of a manual for a toro reelmaster 450-d? free if possible!
try an go to the toro web sit thy have some pdf down loads. i hope this help. if not let me know i'll check my supplers and see.
Oct 15, 2009 | Garden
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
63 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
