Samsung 40" LCD HDTV #LNS4041DX/X Upon cold start-up (either by remote or by using the power button on the LCD set), the power blinks, but the TV does not respond. After depressing the power button slowly several more times (by remote or the LCD power button), the set finally does respond (very irritating). Once the LCD is finally on and running, the set functions normally.
I the same problem and I found that the Capacitors used on the power supply portion of the circuit board were leaking and/or bulging. These parts were failing and as a result the problem worsened with time. If you are able to remove and solder new parts on to the circuit board follow the following procedures. Or get a technician to do the repairs.
1) Make note of connections at back of TV.
Samsung 40" LCD HDTV #LNS4041DX/X - e02b5cd.jpg
2) Unplug power cord and other connectors from back of TV.
3) Remove back of TV with a Phillips (+) star shaped screw driver.
4) Note the position of all connections to the main board.
5) Remove circuit board taking care not to damage any of the components.
6) Locate parts CM806, 811, 812 & 817, all 1000 Samsung 40" LCD HDTV #LNS4041DX/X - a3a1093.jpgcitors.
7) Remove and replace parts with capacitors of equal physical size that are (1000 uf ). I would recommend a voltage rating of 25v or 32v. NoSamsung 40" LCD HDTV #LNS4041DX/X - 5d76107.jpg voltage refers to the amount of voltage the capacitor can handle. The higher theSamsung 40" LCD HDTV #LNS4041DX/X - f5f29a3.jpgpan>
8) Reinstall and reconnect the circuit board.
9) Replace back on TV and setup the unit as before and you’re done.
10) Enjoy!
I replaced the parts for just under $10.00.
Posted on Apr 27, 2009
The problem is that the processor inside your tv has gone out/ you will need to get it replaced but until then you can unplug your tv every night and it will turn on correctly in the morning or whenever you decide to turn it on again. By unplugging the tv, it has time to restart itself instead of sitting in standby mode all night long. The problem may have been caused by a power surge or fluctuation or just by age. If it is a power surge problem i also suggest getting a surge protector so that this does not happen to the next tv you may get.
Posted on Feb 15, 2009
How do i fix my broken power button on my samsung 40 lcd tv?
You can easially just replace the button assembly with included circuit board just unplug your old and plug in the replacement. They are very inexpensive and you can get them for most models at www.tvrepairworld.com
Jan 10, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
Was watching TV, heard a slight "pop" noise then TV went dead - no picture or sound. When I hit the power "on" button on remote, the green light blinks for quite a while (around 40...
Count the number of blinks. Now, Google your make and model with the words blink codes added to the end. This will show you links to sites that will tell you what the blink code means and the problem with your set. The blink code is the sets way of telling the service man what is wrong. From the sound of it, you have a bad capacitor.
Sep 11, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
When I turn TV on with either the remote or push button on front, it automatically switches on and off several times before "catching" and staying on
yes ,, the problem on ur tv is the power supply , u have bad capacitor , now this problem is under recall by samsung , u may want to call 1-800-samsung that way u dont has to pay for repair
Nov 30, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
The screen blinks fast and slow
Tv starting to take longer to power on?Power light indication in the LCD panel screen blinking?Power supply board,starting to have problems.The power supply board,that the board,where the power a/c cord plug into it.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 21, 2010 | Samsung 40 in. Flat-Panel LCD HDTV
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Dec 10, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung LNS4041DX/XAA White horizontal lines
Hi my name is Roety,
I can help you with your issue ,
If the lines are present on every input you most likely have a bad screen. We usually replace the mainboard first because its cheaper .
Check part prices at encompass.com login as a guest
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Clicks on and off several times before staying on
The power supply will sense if the set is 'drawing' too much current and switch itself off. This could be the case here. The power supply board may eventually go completely bad.
Feb 23, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung lns4041dx/xaa
Same problem with my set. The volume was either fully up, or fully down (usually down), and other controls didn't work- like I couldn't access the menus and could not adjust the width of the screen/aspect ratio.
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Jun 03, 2008 | Samsung LN-S4041D 40 in. LCD HDTV
Televison & Video Logo
1,662 people viewed this question
Top Televison & Video Experts
