Question about Continental PS78111 Compact Refrigerator
Professional Series Ice Maker PS 78111 not making ice. Fills with water, I can see water around coils but it is not freezing water.
5 Suggested Answers
  • 9 Answers
SOURCE: Continental electric ice maker CE-IE65151. The
Look at the far ends of the shovel near the attachment hinges. There should be a little plastic tab near the pin on each end and on each hinge. They commonly break off. This is made by e_wave and their model is MCIM30TS. Order parts from Repair Clinic.com
Posted on Jul 21, 2009
My machine just stop making ice and now the water won't even go into the ice case
Posted on Feb 09, 2010
SOURCE: WHERE CAN I PURCHASE PARTS
I need a new circuit board for my Continental Proffessional Series portable Ice maker.Model Ps78111 120v/60hz ref.R134a/37.Need to know where to purchase part and priceThanks Jim .email me at jimjo@cyberback.com
Posted on Jul 26, 2011
imufo2
  • 3773 Answers
SOURCE: the continetal electric ice maker
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 22, 2011
Why is my Uline ice maker filling with water not ice ?
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
Jun 04, 2014 | U-Line ULN Marine Series 12-lb Crescent...
Looking for parts for a Professional Series PS 78111 Ice Maker
It took me a while but for all of you looking for parts for this Ice Maker, it is the exact same product as Magic Chef Model No. MCIM22TS and you can order all parts here
https://www.mcappliance.com/partorder.aspx
Jan 29, 2011 | Continental PS78111 Compact Refrigerator
Ice maker stopped working
Pour about 2/3 cup of water into the icemaker . After freezing , it dumps , replace the dual water inlet valve behind the refrig . If it does not dump the cubes , check that the coils are clean under the refrig at the bottom in front , and if they are and the freezer seems to cool good , then replace the ice maker . NOTE : If the ice maker dumps and not refil with water , replace the valve AND check the tube which fills the ice maker inside , to make sure ice has not frozen inside the tube , which also indicates a bad water valve ( seeps ( not closing completely )) .
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
No ice.
Pout about 2/3 cup of water into the ice maker . If it dumps but does not refill , replace the water inlet valve ( the piece the wall water line connects to behind the refrig ) . Also check the tube which fills the ice maker as it will freeze up , not letting water go into the ice maker . This is also caused by a bad water valve .
If the ice maker does not dump the water poured into it , replace the ice maker .
Also , check that the coils are clean under the front of the refrig , as this will cause slow ice production and can cause the ice maker not to dump due to too warm of temperature . Ice maker has to be 5 degrees to operate .
May 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer drain line and upper drain pan freezes up regularly.
sounds like your fill tube is leaking
you should be able to pull it out from the back of the machine
to inspect it
if the fill tab on the tube is facing in any other direction than down it should be straight down
Oct 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
No water going in the ice maker but water dispener
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold ice maker not filling with water to make ice
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker won't work
If your trying to save a service call you have your work cut out for you. The ice maker is a unit that sits by itself attached to the wall or part of the freezer wall.
There are many reasons why you do not get ice and I will list them.
1- Temp of freezer got too cold and has frozen the pipe that feeds the water to fill the icemaker.
check to see if the icemaker has any ice in the area that fills and makes the cubes.
If the pipe is clogged, very gently put a small tipped screw driver in the fill hose that sites over the ice making row in the ice maker. Be careful you do not push your screwdriver out the back of the refer.
Check to see the freezer temp is not too cold and is freezing that pipe. 0-3 degrees F is good.
2.- check to make sure your water feeding the fridge is on. There is an on off valve to allow the water to feed the icemaker when it needs to fill. This could be bad. there are reset proceedures for the fridge, but unplugging the entire frige for 1 minute and plugging it back in you can listen for the the valve to come on and see if it fills the ice maker resevoir.
3. If it fills and freezes the ice resevoir, then the sensor in the ice tray does not sense the frozen ice and will not cycle and kick cubes. At this point, unless you are super tech, you will need to replace the entire icemaker unit.
Hope this helps.
Mar 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Water leak
IF THE ICE MAKER AND DISPENSER ARE BOTH OFF, THE WATER VALVE IS THE PROBLEM. THERE SHOULD ONLY BE WATER RUNNING WHEN THE ICE MAKER CALLS FOR IT, AND THAT SHOULD ONLY BE ABOUT 7 SECONDS WORTH,
(4 OUNCES).
THE ONLY THING THAT PUZZLES ME ABOUT YOUR DESCRIPTION IS THAT YOU SAY ICE FREEZES OVER THE COMPRESSOR. THE COMPRESSOR IS THE HOT ROUND OBJECT LOCATED UNDER THE REFRIGERATOR OUTSIDE THE COOLING COMPARTMNTS. FREEZING ONLY TAKES PLACE IN THE FREEZER COMPARTMENT. ARE YOU TALKING ABOUT THE EVAPORATOR COILS? IF THERE IS WATER THERE, THE ICE MAKER COULD BE STUCK IN THE FILL MODE AND THE BACK OF THE ICE MAKER FROZEN SO THE WATER CAN'T REACH THE MOLD OF THE ICE MAKER.
CHECK THE FRONT OF THE ICE MAKER BEHIND THE COVER FOR A BROKEN GEAR. IF IT HAS WRITING ON IT THAT SAYS DO NOT ROTATE MANUALLY, YOU NEED TO REPLACE THE ENTIRE MODULE ON THE FRONT OF THE ICE MAKER.
Apr 08, 2008 | Frigidaire GLRS267ZA Side by Side...
Continental PS78111 Compact Refrigerator Logo
119 people viewed this question
Top Continental Refrigerators Experts
John Tripp
John Tripp
Tom Chichester
Are you a Continental Refrigerator Expert? Answer questions, earn points and help others
