Question about Toshiba Satellite P100 Series / Satellite Pro P100 Series. 1...
Satellite Pro P100 Model PSPA4A-005002 Need all
Satellite Pro P100 Model PSPA4A-005002 Need all instruction steps to replace CD/DVD ROM Drive with text and diagrams please Also want Technicians Manual for this Notebook if possible It is old but still working very well Thank You Stony River
2 Suggested Answers
blnewlandjr
  • 54 Answers
SOURCE: toshiba satellite pro p100 screen problem
The LCD can be replaced. The part is around $50-$75 I believe. It can be tricky to replace, but if you take your time, you can save money by doing it yourself. The screen sounds cracked or broken, and black & white will not work either.
good luck
Posted on Mar 19, 2013
Toshiba satellite pro p100 screen problem
good luck
Mar 19, 2013 | Toshiba Satellite P100 Series / Satellite...
Blu-ray won't play
If your Toshiba Satellite Pro isn't reading your DVD-ROM, it means that the DVD-ROM of your computer has been disabled. If your DVD-ROM drive has accidentally been disabled, enabling the DVD-ROM drive is quite a simple task to complete, even for individuals who have little to no experience working with computers.
Click on the "Start" menu and then "Control Panel." Click on "System and Maintenance" in the control panel. Click on "System." Click on the "Hardware" tab and then click "Device Manager." Click on the CD/DVD-ROM drive option and click on it so that it is highlighted. Right-click on the CD/DVD-ROM drive option, and then click "Properties." Click "Enable" in the properties menu and then click "OK." Restart your computer by clicking "Start" and then "Restart." Once your computer has booted, your Toshiba Satellite Pro DVD-ROM drive will be enabled. if still no joy
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it Hope this helps.
Jan 24, 2013 | Toshiba Satellite M645 S4114 I5 2.66ghz...
How difficult is it to replace a CD-ROM drive in a MacBook Pro?
The fact that you realized replacement might be the best option and sought out advice tells me you are intelligent by nature. On a difficulty scale of 1-10 I would rate this in the 6-7 range. Someone like you would probably have very little trouble with this project. I have sent countless step by step instructions over the internet & through email but it seems like the best results always come from an in-depth tutorial, This way you can see EVERY step and even rewind if you're not sure about something. Powerbookmedic.com has a wonderful tutorial on the 17" MacBook Pro breakdown and optical drive (cd/dvd) removal. Just remember to always start with taking the battery out and be very careful about electrostatic shock. You should be fine on a hard surface but I don't recommend fabric/carpet surfaces once you open it up. Here is the link for your laptop. The videos will play in succession automatically. Good luck, you'll do just fine! If you run into trouble, just message back and I will be glad to walk you through it: http://www.everymac.com/systems/apple/macbook_pro/stats/macbook_pro_2.16_17.html
May 03, 2010 | LG SecurDisc 8x External Double-Layer DVD...
HOW DO I CHANGE CD/DVD DRIVE IN A TOSHIBA SATELLITE P105-S6114?
You can use the Toshiba Satellite guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
Sep 21, 2009 | Toshiba Satellite Pro A10 Notebook
How to change the cd player on a toshiba L10
The cd-rom drive on most toshiba laptops has one screw on the bottom or on the top under the keyboard that you simply remove and you can just pull the cd-rom drive out and put another one in. Below is a website that has dismantling instructions.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-M10/replace-laptop-motherboard.htm
Feb 24, 2009 | Toshiba Satellite Pro M15-S405 Notebook
No audio on toshiba sat pro
MAY BE THE ONE YOU TRANSFER THE HARDWARES TO DOES NOT HAVE SOUND DRIVER YOU NEED TO LOAD SOUND CARD DRIVER ON IT BEFOR YOU CAN HEAR SOUND.check the below site and see if it can solve the problem
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-Pro-6100/download/page,sh,31303,221,19,.html
Dec 24, 2008 | Teac DW 28E CD-RW/DVD-ROM Burner
Need instruction "HOW TO" install DVD-ROM multi function drive inToshiba Satellite M45-S265 PC Notebook
Unfortunately I was unable to find a step by step guide for you, however I found a picture of the backside of your laptop. There should be only one screw to remove the cd rom drive located where the red arrow is pointing;
http://img367.imageshack.us/my.php?image=98bd1cl8.jpg
Simply remove that screw and pull out the drive :-)
May 11, 2008 | Toshiba Satellite M45-S265 Notebook
Cd/dvd rom
HELLO. IT SOUND'S LIKE IT COULD BE A COUPLE OFM THING'S MAYBE.? THE FIRST THING IS TO SEE IF . ON YOUR DESKTOP . IN (MY COMPUTER) SHOW'S YOUR DEVICES WITH REMOVABLE STORAGE ... DVD/CD-RW DRIVE WITH A LETTER...LIKE (D:) OR (E:) THEN YOU NEED TO OPEN THE PROPERTIES ON IT.!!!! AND YOU THEN NEED.!!! TO GO ARCROSS THE TOP OF THAT PAGE TO WHERE IT SAY'S HARDWARE AND CLICK ON IT. !!!I IT WILL SHOW YOU HARD DRIVE AND SHOULD SHOW YOUR DVD/CDRW.!!! THEN YOU NEED TO CLICK ON IT.!!! AND OPEN IT.!!! IT WILL SHOW THE PROPERTIES OF DVD/CDRW.!!! AND TELL YOU IF IT IS WORKING PROPERLY.!!! OR NOT.!!! IF NOT YOU NEED TO REINSTALL THE DRIVER'S .!!! FIND THIS OUT AND GET BACK TO ME AND LET ME KNOW.OK.!!! "GOOD LUCK"
Jan 19, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Removing the DVD-ROM drive
hi the removel of the dvd drive is easy as taking out the battry 1. Remove the battery from the bottom of the laptop 2. Make sure the laptop is NOT plugged in. 3. There is a release button for the CD/DVD ROM drive on the bottom of the laptop, simply press and hold the release switch and pull the CD/DVD drive out. replace it with your new 1 good luck
Apr 06, 2006 | Toshiba Satellite Pro A10 Notebook
Toshiba Satellite P100 Series / Satellite Pro P100 Series. 1... Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
