Question about Maytag Neptune MAH6700A Front Load Washer
Neptune mah6700aww washer contol panel removal
A couple of months ago, the buttons on my washer stopped working. I could change settings with the knob, but none of the other buttons worked. Now, when I start a load, it beeps a few times then goes blank and shuts off. From what I have already read, it seems the control panel may need replaced. After taking the screw out from behind the detergent dispenser, how do I remove the control cover?
wagdom
  • 64 Answers
SOURCE: Maytag Neptune MAH8700AWW Front load
You must be on the right track, must be a blockage at the back of the soap drawer, check if junior has posted a toy car! If not turn down the water pressure at the machine stop tap
Posted on Oct 21, 2007
SOURCE: Neptune stackable washer...
I went to Sears today and asked!  They said use high efficiency detergent (marked HE on the label) and put it directly in the washer with the clothes.  Mystery solved!
Posted on Aug 03, 2008
You put the detergent directly on top of the clothes.
Posted on Aug 04, 2008
  • 219 Answers
SOURCE: maytag neptune reading 2E will not work
2e means u have abad motor
Posted on Apr 09, 2009
  • 219 Answers
SOURCE: washer will not drain or run. It gives a code nd
pull back off washer and check your waterpump
Posted on Apr 17, 2009
My washer is making a humming noise and will not run. there are currently clothes and water in the washer
remove 4 screws on the rear panel and then remove the cover, you can see the drain pump remove both hoses on the pump,it is probably plugged up,if it is they wont drain or do anything
Apr 30, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Maytag mah6700aww, Error 2E, Can't Selftest?
I HAVE A MAYTAG NEPTUNE MAH6700AWW ITS GIVING ME THE 3E DISPLAY AND NOT WORKING
Feb 08, 2010 | Maytag MAH6700AWW Neptune Front-Load...
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Contol panel has gone blank and contol panel is hot on right side
try unpuging for awhile then plug back in if doesnt work need to replace board and panel
Apr 06, 2009 | Maytag Neptune Washer
Mel dew on rubber around washer door
you would need to change the bellows gasket
Feb 24, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune Washer-can't adjust water temp. Smokes.
sadly we make no physical repairs like a repair shop will .
Oct 08, 2017 | Maytag MAH6700AWW Neptune Front-Load...
MAH4000 washer
VERY BIG JOB!!
This job requires replacing outer tub. If you want, I can spell out whats involved. Expect at least a couple hours and a pretty large parts bill. Let me know!!
Nov 15, 2007 | Maytag MAH6700AWW Neptune Front-Load...
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH6700A Front Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
