Question about Epson Stylus Photo R300 InkJet Printer
My epson t13 has 3H: head hot error. How can I repair it? It charge every time yhe power is on and error occur when I print.
yooperbud
  • 8637 Answers
SOURCE: Epson 9600 quit printing all
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
SOURCE: I purchase a print head
If you go back to the utility, are you able to confirm that the ink levels for all cartridges are not empty? If so, which are the two colours that do not print?
Posted on Jul 02, 2009
epsinopin
  • 9 Answers
SOURCE: epson 9600 print head missing numerous nozzels
You willl probably need to clean the Pump Cap Assy.
You will need a strong flashlight/clip-on lamp to see what you are doing up in the area you are cleaning.
Move the print head to the left side of 9600. (If you need help with this let me know.)
Use a foam tipped swab slightly dampened with warm water to GENTLY wipe around the seal area of the Pump Cap Assy.
DO NOT USE A COTTON TIPPED SWAB !!!
Dip, Blot, & Wipe. Clean the Foam Swab often to wash off the residue it will pick up. Remenber to keep the swab slightly moist - not dripping wet.
If this does't help, it generally means that the Print Head is also very clogged with gummy/dried ink.
The Print Head cannot be cleaned without removing the Right Side Cover & then removing the Pump Cap Assy. This removing and cleaning is about a 1.5hr-2hr job for an experienced tech. Anyone with moderate mechanical skills can do it though.
Pump Cap Assy cleaning is usually done BEFORE replacing the Print Head.
If the Print Head cleaning doesn't work then a New Print Head is in order.
Hope this helps ! Good Luck !
Posted on Sep 25, 2009
pineworks
  • 4041 Answers
SOURCE: Epson 1900 inket print head clogged
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 07, 2010
  • 1218 Answers
SOURCE: Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Posted on Oct 04, 2010
Will not print black only. Changed ink cartridge 3 times, performed all maintenance repeatedly, but will still not print black ink.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 01, 2012 | Epson Stylus CX9400 Photo Printer
Printer error
Here a few common problems that your Epson printer and ink cartridge can suffer from.
Improper Installation of Cartridges
A common Epson printer and ink cartridge problem! If you have changed the ink cartridges then you might just receive this error message. The message might state that the cartridge is not installed correctly in the printers. In such cases, re-install the cartridge in the correct manner. If the problem persists then it is advisable that you replace the cartridge as it might be defective. If you still get the same error message on installation of the replacement cartridge then its time that you clean the print head. You could do this yourself or could take it to a repair facility.
Printing Failure
Failure to print documents is yet another common problem with respect to Epson printers. The print heads of Epson printers are sensitive and this sensitiveness is the culprit behind such problems. If the print head is clogged or blocked you will have to unclog or unblock them. This can be done by using a special fluid that is available for just this purpose only. This fluid flushes the print head, and your printer is once again ready to print.
Communication Error
'Communication Problems' are yet another one of the common problems surrounding Epson printers. Once you give the print command you might be shown the message that there is a communication error between the printer and the computer. This means that there is the occurrence of a minor problem. One of the reasons for this problem could be the inappropriate selection of printers from the print options menu. Cable connections should also be checked. Another solution could be the re-installation of the driver of the printer.
Print Jobs that are Slow or Incomplete
These are problems that occur during an ongoing process. The printing might stop midway and then start again after some time. At times, the printing process will repeat itself several times and then finish printing the page. There are times when the page will finish printing, but you will find that it is an incomplete print. More often than not, this is not a printer related problem.
What might have happened is that the driver might have corrupted or a virus might have infected the computer; or a spyware might be affecting the working of the printing process. If such a problem occurs, the best solution would be to scan the computer for viruses and spyware. As can be seen these common Epson printers and Epson ink cartridge problems can be sorted out quite easily.
hope it helps..
Thanks for using fixya...
Dec 04, 2010 | Epson Office Equipment & Supplies
Power light is out and the two amber lights are flashing at same time.
Power off and paper and ink flashing alternately:
Parts inside the R1900 Series are at the end of their
service life or an unknown error has occurred. Contact
Epson for help
Power off and the paper and ink flashing fast:
The print head is obstructed by paper or other foreign
material. Turn off the printer, remove any obstructions,
and turn it back on. If the error persists, contact Epson
Good Luck!!!
Nov 02, 2010 | Epson R1900 Printer
Epson rx650 printer service shutdown repair. Can anyone help to get this printer going again? For 6 days it gave message service required and then an error message with only shut down option. Regards...
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
NOTE ! You can lost Epson lifetime guarantee on print head by refilling ink cartridges!
Latest versions changes:
Apr 26, 2010 | Office Equipment & Supplies
The error light on the Epson TM-T88IV keeps flashing whats wrong with it?
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Oct 23, 2009 | Epson TM T88 Thermal Printer
Fatal error
This error can occur if a supposed print out failed to completely print and it stopped try to power off, unplug/ replug the connections that is the power cord and the usb cable.
when you replug all of it then power on then print.
IF IT STILL PERSIST:
most common fatal errors are when the carriage failed to move to its proper place. this normally can be resolved by 1st power off your printer open the printer cover and then check were the printer head is positioned. if its on the left manually move the printer head to the left then right for about 2 inches just to somesort reset it. if it still persist check for any obstructions that may have blocked it.
Sep 11, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson PictureMate - can't clean all nozzles & Error P
Many times head cleaning will throw much ink away. 1 time about 10% of ink. After meny times head cleaning, ink will out, and need replacement. May be after head cleaning nozzle is ok, but after replacement, printer do ink charge. It may be distrub the flow of ink at head. Is the cartridge new?. Use CISS for continuity printing.
Jul 26, 2009 | Epson PictureMate C11C623001 Photo Printer
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson CX6600 Only Prints/Copies Blank Pages. Is there a solution other than tossing this Epson produce failure? dlvacek2@comcast.net
This is a common problem with Epsons. With Epsons, they have a printhead that lasts for the entire life of the printer. These problems usually occur when you change cartridges and put fresh ones in and it does that charge. There is a long tube that goes down to a big pad that all waste ink drains into. Eventually, the ink hardens and builds up, plugging the tube. The worst thing you can do is clean the heads. My advice is to buy new, or have a repairman clean the heads with hot chemicals.
Feb 26, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus Photo R300 InkJet Printer Logo
546 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
