Question about Orion SkyView Pro 100mm ED EQ Apo Refractor Telescope
Ra ascenntion lock release does not release
The ascention release lock when release does not release the assescion axis to glide
  • 3,186 Answers
Contact Orion customer service:
http://www.telescope.com/control/main/
Posted on Oct 15, 2009
2011 road glide steering locked can't release What do I do?
Hi Anonymous, try pulling hard left in a rocking motion at the same turning the key. Good luck
Nov 17, 2013 | 2011 Harley Davidson FLTRUSE CVO Road...
My rasonic tv model ra 14rns is lock how to open lock
I HA RASONIC TV MODAL RA-14RNS HE IS DESPLY LOK HO VE UNLOK HAM
Apr 07, 2012 | Master Lock 5400d: Portable Select Access...
Where is the declination clutch located?
RA moves the polar axis--- and DEC moves the scope from side to side.
There are two knobs that turn these two axis.
See this:
http://www.themcdonalds.net/richard/index.php?title=Polar_Alignment_of_your_Equatorial_Mount
Dec 30, 2010 | Celestron AstroMaster 114 AZ (50 x 114mm)...
Polar alignment with cg5 mount in the tropics
Wait what? You just have to remove the front bracket for the alt screw and you can go lower than 30 degrees.
Feb 21, 2010 | Celestron CG-5 Mount Telescope
I have a problem whith the RA axis. It runs 1/3 of
Don't think you will find a manual anywhere on the internet.
Try using Google but I don't think any exist.
A grinding noise indicates the gears are broken or not engaging properly. Sorry.
Oct 14, 2009 | Takahashi FSQ-106/EM-200 (229 x 106mm)...
I need to re install my ascentive performance center
StopBadware.org released a badware alert about PC SpeedScan Pro today:
We find that PC SpeedScan Pro is badware because it does not disclose the fact that it installs additional "Performance Center" software and fails to remove this software when PC SpeedScan Pro is uninstalled, and because it repeatedly displays notifications that exaggerate the performance impact of various ‘errors’ found on users’ computers, in order to induce users to purchase the full version of the software.
The software was distributed via a website called finallyfast.com.
We attempted to contact the software publisher, Ascentive, via e-mail, but we did not receive a response.
We currently recommend that users do not install PC SpeedScan Pro, unless users are comfortable with the behaviors we have identified or until the application is updated to be consistent with the recommendations made in this alert.
I had been hearing a lot of good things about the Ascentive Software release of PC SpeedScan Pro. It claims to get those gigabytes of data you have accumulated straightened out and get your computer running like new again. PC SpeedScan claims to fix registry errors that can make your computer slow while it sorts through the errors as you are accessing your programs and files. Apparently it does not work too well. See our recommended computer optimization programs here.
After hearing some of the complaints about the Ascentive software, you may want to stick with computer optimization programs that have stood the test of time. Here are some good reviews on SpeedUpMyPC 2009, TuneUp Utilities 2008, and Optimize 2.0 - definitely worth a look!
I would personally recommend ncleaner. It has been my hands-down champion for months now.
Trust me Albert, stay away from the ascentive con-artist program. ncleaner will clean up your machine, and I also recommend you scan with Spybot, as Ascentive might have dumped some cookies on yr machine.
Good Luck and Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Computers & Internet
I need to re install my ascentive performance center for the speed scan pro application
Chris (ziraffa)
Ascentive Performance Center
I need to re-install the Ascentive Performance Center
Nov 21, 2008 | Computers & Internet
Can't release RA axis manually
I had one come in like this. AS you say the RA axis should be free to rotate in the RA housing when the clutch lever is released. The cylinder that the worm is machined on is binding on the axle. This doesn't overly effect normal tracking, but makes gross adjustments impossible. The only solution is to tear the mount down and finish the parts to eliminate the interference. Google astronomyboy for the how to. I have to warn you that I had to heat the cylinder and axle in the oven at 250 for 30 minutes before they would separate. don't use the wife's good oven mits!! When I finish these parts I use Soft Scrub (w/o bleach) as a grinding compound. It's basically bicarb in a jell. HTH, Geo.
Nov 01, 2008 | Celestron CG-5 Mount Telescope
Code for innovage product (oversized remote)
you will be able to do this as long as your universal remote also has the option to "code search". if it does take these steps.
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Jul 29, 2008 | Televison & Video
Orion SkyView Pro 100mm ED EQ Apo Refractor Telescope Logo
246 people viewed this question
Top Orion Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
deton8 von Splosion
Tony Parsons
Tony Parsons
Are you an Orion Optic Expert? Answer questions, earn points and help others
