Question about Kenmore Dishwashers
We have a Kenmore Ultra Wash Dishwasher, model 665.1359 or 1369 (not sure which) that is dead. There is still water in the bottom of it from the last running. We checked the circuit breaker and the
No lights on machine, nothing happens when push buttons, water in bottom, circuit seems ok, plug has power to it.
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
SOURCE: Kenmore Ultra Wash Dishwasher: Lock On Button Issue
Have to hold the Air Dry button down til your finger hurts. Release button and the light will go off. The "4 second press" in the manual is incorrect!
Posted on Jun 24, 2008
SOURCE: My kenmore ultra wash model
my model #665 dishwasher will not pump water into the unit
Posted on Jul 15, 2008
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
The sequence of "Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses)" worked for us. Many thanks!
Posted on Oct 14, 2008
I have a Kenmore Elite Ultra Wash Dishwasher 665.1319 and it won't get rid of the water it used completely
check the positioning of the waste water hose from the pump
it could be kinked from the re-installation, too high to drain or other re-modelling problems
Sep 04, 2015 | Kenmore Dishwashers
Water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Nov 02, 2012 | Kenmore Dishwashers
Hello, I have a Kenmore Ultra Dishwasher, model # 665.16533200. Lately the top rack dishes have not been getting clean. Also the glasses with indented bottoms, that are normally full of water at the end of...
might wanna check the connections on the back of it and make sure nothing has broken behind it....also may wanna get a mop and some towels something tells me its throwing water out the back side of itself while its running
Apr 16, 2017 | Kenmore Elite Stainless Steel 24" BuiltIn...
The top rack on my kenmore ultra wash 3 dishwasher does not come clean and now even the bottom is starting to not clean
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My Kenmore Ultra Wash Dishwasher Model#665.13842K600 doesn't fully drain a the end of the cycle. There is always dirty water left in the bottom of the unit.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 02, 2010 | Dishwashers
Trouble shooting kenmore dishwasher
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Oct 03, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwasher does not want to drain
Make sure that the draining-hose is clean .... Try to put the draining-hose downwards .... it is possible that the pomp can not push the water high enough .... if the hose runs downwards ... gravity will help !
Jul 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
229 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
